Suddenly everything stops **solved**
webcam
Post by webcam »
Something is wrong with my system. Suddenly nothing is uploaded anymore. Then you have to restart the system again and again.
Greeting
Daniel
webcam
Re: Suddenly everything stops
Post by webcam »
Just found out that I can't restart the system either.
How to reinstall Meteobridge?
First before reinstalling anything you need to confirm what the issue is, as it is not normal for a system to all of a sudden simply stop working, stop uploading and typically it is generally with some outside help, network, router, ISP ??
webcam
Post by webcam »
I checked everything and everything is in place.
I turned it off again and then it works again for a short time. At 8:50 a.m. it stopped again. It's also strange why I can't restart the system via the browser.
Greeting
Daniel Suter
webcam
Post by webcam »
Here is the log file.
oled (28.01.2022 23:23:16): process started.
database (29.01.2022 08:47:54): process started.
database (29.01.2022 08:47:54): Content of RAM database restored.
wnetd (29.01.2022 08:47:57): process started.
system (29.01.2022 08:47:57): start of logging process initiated.
wnetd (29.01.2022 08:47:57): send data thread started (pid:2468 tid:2469)
logger (29.01.2022 08:47:57): databases connected. Update interval 3600 seconds.
logger (29.01.2022 08:47:57): data logger (version 5.2, build 14655) started.
logger (29.01.2022 08:47:59): connect station 0 (WS600/700/10 via USB serial).
logger (29.01.2022 08:47:59): connect station 9 (System Data via Plug-in).
logger (29.01.2022 08:47:59): station 0 (WS600/700/10), compact weather station device 7-1 activated: WSx-UMB
logger (29.01.2022 08:47:59): station 0 (WS600/700/10), compact weather station device 7-1 identifies as: No. 220, Project 1305, HW 0.11, SW 0.0, device 238
logger (29.01.2022 08:47:59): station 0 (WS600/700/10), compact weather station device 7-1 provides 13 channels: 100, 101, 110, 200, 300, 305, 460, 400, 401, 500, 700, 600, 800, 900
logger (29.01.2022 08:48:01): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2022 08:48:01): services paused.
logger (29.01.2022 08:48:03): sensors are now providing data.
logger (29.01.2022 08:48:03): services started.
database (29.01.2022 08:48:19): database sync done (49 tables, 27/1862 writes).
system (29.01.2022 07:51:06): stop of logging process initiated.
logger (29.01.2022 08:51:06): parent process received termination signal (15).
logger (29.01.2022 08:51:06): child process received termination signal (15).
logger (29.01.2022 08:51:07): disconnect station 0 (WS600/700/10): exit
logger (29.01.2022 08:51:07): disconnect station 9 (System Data): exit
wnetd (29.01.2022 08:51:08): process received SIGTERM signal (15) and terminated.
webcam
Post by webcam »
And this is what it looks like after a reboot
oled (29.01.2022 07:47:51): process started.
database (29.01.2022 10:55:31): process started.
database (29.01.2022 10:55:31): Content of RAM database restored.
wnetd (29.01.2022 10:55:34): process started.
system (29.01.2022 10:55:34): start of logging process initiated.
wnetd (29.01.2022 10:55:34): send data thread started (pid:2476 tid:2477)
logger (29.01.2022 10:55:35): databases connected. Update interval 3600 seconds.
logger (29.01.2022 10:55:35): data logger (version 5.2, build 14655) started.
logger (29.01.2022 10:55:37): connect station 0 (WS600/700/10 via USB serial).
logger (29.01.2022 10:55:37): connect station 9 (System Data via Plug-in).
logger (29.01.2022 10:55:37): station 0 (WS600/700/10), compact weather station device 7-1 activated: WSx-UMB
logger (29.01.2022 10:55:37): station 0 (WS600/700/10), compact weather station device 7-1 identifies as: No. 220, Project 1305, HW 0.11, SW 0.0, device 238
logger (29.01.2022 10:55:37): station 0 (WS600/700/10), compact weather station device 7-1 provides 13 channels: 100, 101, 110, 200, 300, 305, 460, 400, 401, 500, 700, 600, 800, 900
logger (29.01.2022 10:55:40): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (29.01.2022 10:55:40): services paused.
logger (29.01.2022 10:55:41): sensors are now providing data.
logger (29.01.2022 10:55:41): services started.
database (29.01.2022 10:55:53): database sync done (49 tables, 0/1862 writes).
webcam
Post by webcam »
Hi there,
So it must be up to the Meteobridge Pro. Currently my Raspi is running with Meteobridge and I have no problems.
Unfortunately I need my Raspi for other things.
Can't find any instructions on how to reinstall Meteobrige.
Greeting
Daniel
Not a Raspi user, so when you say the Raspi is running with Meteobridge I am assuming you mean the Raspi connects to the Lufft ok using the same interface without problems, correct?
webcam
Post by webcam »
Hi there,
yes, that's exactly what I mean.
Connected the USB cable from Meteobridge to the RASPI and it works.
Checked this morning and it's still working.
Greeting
Daniel
when you send remote login details to "info(at)meteobridge.com" I can have a closer look.
The error description "stops uploading" does not provide enough information to draw any conclusion.
webcam
Post by webcam »
Since my Meteoridge Pro is a bit older, I bought a new one. Works great with no problems. No more interruptions either.
Maybe I'll send the old one to swisswetter.ch, maybe he'll find out something that's defective.
Greeting
Daniel
jhausladen
Post by jhausladen »
webcam wrote: Thu Feb 03, 2022 4:22 pm Since my Meteoridge Pro is a bit older, I bought a new one. Works great with no problems. No more interruptions either.
Greeting
Daniel
Did they already find something?
I do think, that I have a similar problem as you do :-/ viewtopic.php?f=56&t=16129
jhausladen
Re: Suddenly everything stops **solved**
Just for anyone that may come across this post having similar issues. In my case the hardware was faulty and has been replaced. Now the station is working fine again :D
