Meteohub Update 4.2a
What's hot...
AAMFlyer
Re:Meteohub Update 4.2a
Post by AAMFlyer »
Boris - just sent you another message....still not working correctly.....good for 4 mintues after recomputation - but then stops again....
Digging deeper into this I found a hw-clock issue with ebox that causes time jumps after reboot on Greg's rig. This results in wrong time stamps of logged data which puzzles all follow-up processes. I am just working on a bug fix... but it has been a long way to get to the system time problem. I hope, we are now down to the root cause of all trouble reported in this thread... stay tuned.
AAMFlyer
Post by AAMFlyer »
I think you got it!!! :cheer:
Sent you an email with another side question that may or may not be related on the updating of the data in the clientrawhour file - even though I update it every 1 mintue - the data only changes/updates every 5 mintues - although this may be normal and I've never noticed it.... Will keep an eye and report back later today!!!
minapija
Post by minapija »
Hi All,
I have this problem, after update to 4.2a, all internet uploads did only several times (5x or something like that) and however ftp connection is without problem (I did test from admin and it was ok) meteohub doesn't upload WD Live files, xml files nothing. Does anybody have similar problem?
AAMFlyer
Post by AAMFlyer »
What box are you using....Ebox? Try loading the update again and then going through your setup pages and hitting save on each page.....that sometimes fixes things too....
minapija
Post by minapija »
I use NSLU + VP2. In system log there are such rows like it wanted to upload data to server (CRON info), but nothing happened.
can you please open ports 22 and 7777 on your router, forward these to your Meteohub LAN IP and send WAN IP to "info(at)meteohub.de". I might be able to have a look into that later the evening.
It has turned out, that problems with file system on USB stick was the root cause for the trouble.
