jmontamat
Post by jmontamat »
Thank you so much!!!
good morning sorry for the inconvenience, i removed the original link to download back in June i think as there is an updated version (June-July 2022) to support new purple air and some other minor changes .i will send it to Boris on sunday (14th August) , just been rather preoccupied with traveling and boating(sailing)..
ps graham “Gwolf” if your reading this ill be around all day on wednesday 17th August to help with weatherflow lightning .
brian
Thanks, I inserted Brians link in the initial posting.
lorenz1982
Post by lorenz1982 »
Hello. How can I add only the latest changes? Is there also a "simple update"?
Thank you.
MeteoBorgo: www.meteoborgo.it
lorenz1982 wrote: Sun Aug 14, 2022 9:53 am Hello. How can I add only the latest changes? Is there also a "simple update"?
Thank you.
hello lorenzo
simple updates are available to those that contributed to requests of dart accessories and provided code support .updates via email only the simple updates are no longer publicly or forum available.if you wish to receive simple updates please make a polite request via email , please dont worry i no longer request anything and I know yourself have contributed in the past with support so its no problem. current simple update for august was just released today basically contains updated lunar , equinox events upto 2024.that is also probably last update for this year or until there is a significant PHP release i.e PHP 9.
brian
lorenz1982
weatherist34 wrote: Thu Aug 18, 2022 2:11 pm
Thank you.
hello lorenzo
brian
Hello.
I have already sent an email with the request last week to the address: info@weather34.com but it gave me a delivery error ☹️
Good morning
info@weather34 is no longer valid try my apple mail
edit ..got your email so added your email to list should have received an update to run..
have a good day..brian
lorenz1982
weatherist34 wrote: Fri Aug 19, 2022 6:34 am Good morning
Thank you Brian.
I have received the update.
Thank you so much.
masgio69
Post by masgio69 »
Hi everyone, I state that I searched the forum but I did not find what I was looking for, I configured the weather34 and it works fine ( http://meteopiova.altervista.org/meteob ... theme=dark) but I would have a couple of questions for you. First question: I can't get the forecast to work even though I entered the API Weather Underground bees correctly. Second question: I can't change the dewpoint section or avg wind speed with the webcam section. Thanks a lot to those who can help me.
masgio69 wrote: Sun Aug 28, 2022 6:05 pm Hi everyone, I state that I searched the forum but I did not find what I was looking for, I configured the weather34 and it works fine ( http://meteopiova.altervista.org/meteob ... theme=dark) but I would have a couple of questions for you. First question: I can't get the forecast to work even though I entered the API Weather Underground bees correctly. Second question: I can't change the dewpoint section or avg wind speed with the webcam section. Thanks a lot to those who can help me.
good afternoon
ive just run the stationcron.php file manually on your site url . you should now see the forecast updated for your region/area .you need to setup this in meteobridge to run every 30 minutes or 60 minutes
look for the setup.pdf in the master download …
via meteobridge services your domain/weather34/mbdbfiles/stationcron.php 30 or 60 minutes
brian…
masgio69
Post by masgio69 »
weatherist34 wrote: Mon Aug 29, 2022 12:59 pm
good afternoon
brian…
Thanks you so much brian , the forecast work well now.
And for the 2nd question? I can't put the webcam in place of dewpoint or avg wind speed.
Thank you very much for helping....
masgio69 wrote: Mon Aug 29, 2022 4:58 pm
good afternoon
brian…
hello sure no problem but have to wait till next week my laptop is in apple service for a new battery.i can simply add an option in setup screen to wind average modules position to select webcam .
please email has updates are not forum public available i will push an update via group email .
brian34design “at” icloud.com
if there are any other options required please feel free to ask. but lets not make it complicated and messy.. :D
masgio69
Post by masgio69 »
Thank you so much , do you have my email?
masgio69
Post by masgio69 »
Actually I realized that in the dew point section I could put the webcam section, but it is not saved using template layout 2 but changes it using template 1. Where am I wrong?
good morning
no i dont have your email please make a request via email given above..update for webcam is ready to distribute via email list.
brian
