Auror default password. **solved**
Churchtownweather
Post by Churchtownweather »
Hi could you tell me the default password for Aurora
thanks Brian
Re: Auror default password
It is empty, just press "login".
Churchtownweather
mthiessen
Post by mthiessen »
I have the same problem.
When I press LogIn without a password it redirects to this URL and I get a 404 Not Found.
When I use Weather34 LogIn without a password I get a long string of numbers in the URL between "https://admin.meteobridge.com/" and "PWS4". And I get the admin page.
mthiessen wrote: Thu Sep 08, 2022 5:50 pm I have the same problem.
OK, so your are trying to use this via remote login, not directly within your LAN, right?
mthiessen
Post by mthiessen »
Correct.
I tried on my NANO SD and it works even in the remote login situation.
Could you please send me your remote login to "info(at)meteobridge.com" which allows me to test on your device?
Just released update does fix this.
mthiessen
Re: Auror default password. **solved**
Post by mthiessen »
Thanks. Fixed!!!
