problems to use my WH2650A (Ecowitt) **solved**
meteosantasusanna
Post by meteosantasusanna »
I have problems to use my WH2650A (Ecowitt) on meteobridge with raspberry. i have another meteobridge with dlink router and it works fine but in raspberry they will not find the sensors.
at the dlink the sensors are correct:
rain0!0rate rain0rate rain rate (hourly)
rain0!0total rain0total rain fall (total amount)
sol0!0rad sol0rad solar radiation
th0!0dew th0dew outdoor dewpoint
th0!0heatindex th0heatindex outdoor heatindex
th0!0hum th0hum outdoor humidity
th0!0temp th0temp outdoor temperature
thb0!0dew thb0dew indoor dew point
thb0!0hum thb0hum indoor humidity
thb0!0press thb0press pressure
thb0!0seapress thb0seapress sealevel pressure
thb0!0temp thb0temp indoor temperature
uv0!0index uv0index uv index
wind0!0avgwind wind0avgwind average wind speed
wind0!0chill wind0chill wind chill
wind0!0dir wind0dir wind direction
wind0!0wind wind0wind wind speed
but on raspberry:
data0!10num data10num CPU load
data0!11num data11num uptime
data0!12num data12num data storage usage
data0!13num data13num RAM usage
data0!15num data15num processes
data0!16num data16num data age
t0!9temp t9temp system temperature
i use exactly the same configuration for the weather station.
Where ist the problem for that?
When i reset the station than it goes 1 o 2 minutes than stalles:
protocol:
logger (25.09.2022 10:55:10): databases connected. Update interval 3600 seconds.
logger (25.09.2022 10:55:10): data logger (version 5.4, build 2876) started.
logger (25.09.2022 10:55:10): connect station 0 (Observer-IP via SW Driver).
logger (25.09.2022 10:55:10): connect station 9 (System Data via Plug-in).
logger (25.09.2022 10:55:13): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (25.09.2022 10:55:13): services paused.
logger (25.09.2022 10:55:44): error while doing write on socket 5551 (22): Invalid argument
logger (25.09.2022 10:57:13): give up waiting for sensors after 120 secs.
logger (25.09.2022 10:57:13): services activated.
logger (25.09.2022 11:05:40): child process received timeout signal (14).
logger (25.09.2022 11:05:40): disconnect station 0 (Observer-IP): exit
logger (25.09.2022 11:05:40): disconnect station 9 (System Data): exit
logger (25.09.2022 11:05:41): data logger stopped.
logger (25.09.2022 11:05:41): databases disconnected.
logger (25.09.2022 11:05:41): parent process to be terminated.
logger (25.09.2022 11:05:41): databases connected. Update interval 3600 seconds.
logger (25.09.2022 11:05:41): data logger (version 5.4, build 2876) started.
logger (25.09.2022 11:05:41): connect station 0 (Observer-IP via SW Driver).
logger (25.09.2022 11:05:41): connect station 9 (System Data via Plug-in).
logger (25.09.2022 11:05:44): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (25.09.2022 11:05:44): services paused.
logger (25.09.2022 11:07:44): give up waiting for sensors after 120 secs.
logger (25.09.2022 11:07:44): services activated.
Gyvate
Re: problems to use my WH2650A (Ecowitt)
Post by Gyvate »
are you sure you are using the proper driver ??
If you really have a WH2650, then the Meteobridge driver should be GW1000 and NOT ObserverIP.
(Station --> Primary)
ObserverIP is an old device of the WH2600 type and does not have the Ecowitt Gateway (old name GW1000) API.
They look similar from outside but are not.
Have a look at https://www.wxforum.net/index.php?topic=40970.0
where you will get a good explanation and understanding of the WH2650 and the difference to an old ObserverIP device (WH2600).
This has (should have) nothing to do with the RaspberryPi - I'm running a WH2650 on RPi4B via the MB GW1000 driver without any issues.
And should have nothing to do with the dlink router either.
The WH2650 is a WLAN/"WiFi" device which connects to your router and your local network either directly or via an access point (often the Access Point is part of the router if it is a so-called "WiFi router").
