My new Meteobridge PRO2 showed an error this afternoon. Everything works fine now, no restart needed so far.
wnetd (05.12.2022 15:41:36): process received SIGTERM signal (15) and terminated.
logger (05.12.2022 15:41:38): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (05.12.2022 15:46:16): message above repeats 133 times.
test5m (05.12.2022 15:46:16): weathernet daemon stalled, will be restarted now.
logger (05.12.2022 15:46:19): open named pipe "/dev/meteobridge" failed: Invalid argument
logger (05.12.2022 15:46:19): message above repeats 1 time.
wnetd (05.12.2022 15:46:19): process started.
wnetd (05.12.2022 15:46:19): send data thread started (pid:10383 tid:10403)
I will save logging up to now (from December 1th) because more errors are displayed.
Is this the right place to post errors?
Kind regards,
Richard
wnetd process terminated on PRO2
Re: wnetd process terminated on PRO2
Hard to say what causes this. Are weather network services running ok?
Yes, weather network services run fine.
I noticed the error a few days ago again, but did not copy the messages and rebooted in the mean time.
Is historic logging available somewhere on the Meteobridge?
