A month or two ago, I had a problem with meteobridge, it completely exited the configuration and deleted all my information. After I fixed the problem, the windfinder is not sending the data properly. The temperature is not the same from the console and neither is the air pressure.
I am getting this message in the upload status:
html" lang="en-US" xml:lang="en-US"> <head> <title>Untitled Document</title> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> </head> <body> - ERROR! Your password doesn't match. Please set your ID and password in the meteohub weather networks panel. For any questions please contact info@weerhuisje.nl or support@windfinder.com </body> (unlimited more tries, next in 30 secs)<BR>')">
How Can i fix this problem?
Windfinder is not working good! Please help! **solved**
- meteobridge.png (66.15 KiB) Viewed 1195 times
Re: Windfinder is not working good! Please help!
I read that as your ID/Password does not match?
Have you re-entered your User Name and Password correctly?
Please change to "no retries" as repeating packets with wrong user/password will just queue up the problem.
In general, repeats of packets when you update every 30 seconds anyway does not make sense. You can easily afford a drop.
Well, I wrote my data correctly in the windfinder, you can see in the "Weather Network" column that my data is written correctly!
I have also sent an email to windfinder to see what they are saying.
- Weather Network.png (73.75 KiB) Viewed 1161 times
I contacted windfinder and today they fixed the problem!
Thank you all!
Thank you all!
