Good morning
you seem to have resolved some issue but yes zip extension in php itself is required and with every new option applied to the setup options this is required to be set , I have numerous times highlighted these but this thread grows rapidly and often I request Boris to open a new one as sometimes or most of the time some information gets lost in the volume of posts..
but as always feel free to email brian34design"at"icloud.com for help if needed but do bear in mind time differences Im an early bird at present its ramadan here to 21st April so always around before sunrise ..
anyway cant help on the timezone issue not sure Im understanding why one particular year is not functioning and others are ..again provide a url so I can get a better idea often a page resource view will reveal the anomaly ..
have a good weekend..brian
- jmontamat
Hi Brian here I crash can someone help me with purple air max on weather34-chart-daymaxmin.php ??
- jmontamat
Hi again Brian.
the colors of the earthquake module do not match.
Thank you.
Good weekend.
Thank you.
Good weekend.
- Sin título.png (17.07 KiB) Viewed 35444 times
Hello Josepjmontamat wrote: Sat Apr 08, 2023 12:48 pm Hi again Brian.
Thank you.
Good weekend.
all corrected and added day max/min for purple air/davis airlink
Simple-Update-Aurora-MKII-April-2023-Rev-M.zip
https://www.mediafire.com/file/btf6lifb ... M.zip/file
famous last words but I hope thats it for a while ...
brian
- jmontamat
I have found my problems:weatherist34 wrote: Sat Apr 08, 2023 2:41 pm
Hello Josep
{$packmax += [str_replace(' ', '-', $row[1]) => $row[2]];}}
I did not contemplate time $row[1] I had it as row[0] and I did not know how to use two .csv files before it was all in 1
Thank you so much .
- jmontamat
Good morning, I have seen a gap between daylight and remaining.
half an hour passes before it does not occur on sun-moon-page.
Thanks and good week.
- Sin título.png (96.83 KiB) Viewed 35383 times
hello Josep
out of luck I am afraid just preparing a long overdue GDPR option(available end of today) ..purely optional via setup screen and then unfortunately my laptop is off to apple service for a new keyboard as I stupidly spilt coffee on it ..
- jmontamat
No problem luck.
- jmontamat
Good morning.
If it's any consolation, I like the design of your cookie bar better than mine.
Accidents with laptops happen.
The worst for me are the cats to find where they hide the letters "keys" of the keyboard they steal,
- Sin título.png (90.43 KiB) Viewed 35255 times
- ConligWX
Hi Brian.
just a cosmetic thing. the /weather34-layout-options.png file only shows 5 templates and not 6.
Regards Simon
https://www.conligwx.org/pws
Good morning to you both
Simon all noted next update will add it next update ..thank you
Josep final GDPR thingy ended looking like screenshot below and has always I tried to design it to match template colour etc , unfortunately not enough time prior sending laptop off to service and we also have a festive holiday kick in next week so unlikely anything will happen this side of April unless it miraculously returns prior to the start of the holiday .
It was requested by Gary at https://whaleybridge-weather.com/weathe ... hboard.php so the final version is there in use
so next update it will be available and it is purely optional via setup screen for those that find it inconvenient .. I do but typical EU shite regulations !
Cats I miss our cat ( photo below ) immensely she passed away a few years ago 14 years we had her it was tough ..
- jmontamat
I have had eight Cats face one one characters.
the hawksbill the smartest.
after her only one more.
- IMG_1194.png (196.15 KiB) Viewed 35204 times
Simple-Update-Aurora-MKII-April-2023-Rev-P
https://www.mediafire.com/file/pw71irrt ... P.zip/file
adds GDPR compliant pop up cookie box .important please set the new option in the setup screen to use simply either yes or no .
todo in May 2023 !
1. tweak the sun module ..
2. complete theme 7 basically replicates new Davis console display with some minor differences so not to infringe !!!
thats it for until May ..ramadan finally finishes tomorrow so we begin a short festive period here this year and its time for travelling ..brian..
todo in May 2023 !
Good afternoon
before we go on a small adventure to Riga then onto Dubrovnik but something to digest which will appear in early May .Whole idea really triggered off from requests for a separate rain rate graphic so after much thought , trial and error scenarios to see what would be most suitable with options it came out like this.
the wind direction/speed module along with rain/rate gauges are optional you can revert to original basic layout for that module simply by selecting a new option in the setup screen.
bottom modules were reworked and pretty much simplified the code. These are not ready made JavaScripts they are purely css svg crafted by myself
I enjoy css compiling Im not a lover of using ready made hacked up scripts, doing it this way you actually learn how the code works especially useful when things go a bit wonky..stick around things will evolve year on year as browser capabilities get richer ..
UVINDEX or Solar module shifted to 1st bottom module if no uv or solar displays whatever module optional you select i.e forecast,feels,fire risk etc
the circular gauges are dynamic realtime particularly appealing visually when wind speed is rapidly changing etc
wind speed all popular units catered for m/s,mph,kts,km/h,bft
wind direction/speed gauge module is colour coded as examples below
I hope it is to your liking as above there options to revert to original
