Hi It seems, I have a DB error or something with the disk?
These messages are coming endless. I also tried to delete the database content only back to one year, nothing help.
logger (30.05.2023 18:41:16): error (125) while doing bind (port 5553): Address already in use
logger (30.05.2023 18:41:17): process "19915/sync" stalled in "disk sleep".
logger (30.05.2023 18:41:17): killed process "19915/sync" listening to port 5553.
logger (30.05.2023 18:41:46): databases connected. Update interval 3600 seconds.
logger (30.05.2023 18:41:47): data logger (version 5.4, build 14972) started.
logger (30.05.2023 18:41:47): error (125) while doing bind (port 5553): Address already in use
logger (30.05.2023 18:41:47): process "19915/sync" stalled in "disk sleep".
logger (30.05.2023 18:41:47): killed process "19915/sync" listening to port 5553.
logger (30.05.2023 18:42:16): databases connected. Update interval 3600 seconds.
logger (30.05.2023 18:42:16): data logger (version 5.4, build 14972) started.
logger (30.05.2023 18:42:16): error (125) while doing bind (port 5553): Address already in use
logger (30.05.2023 18:42:17): process "19915/sync" stalled in "disk sleep".
logger (30.05.2023 18:42:17): killed process "19915/sync" listening to port 5553.
logger (30.05.2023 18:42:46): databases connected. Update interval 3600 seconds.
logger (30.05.2023 18:42:46): data logger (version 5.4, build 14972) started.
logger (30.05.2023 18:42:46): error (125) while doing bind (port 5553): Address already in use
logger (30.05.2023 18:42:47): process "19915/sync" stalled in "disk sleep".
logger (30.05.2023 18:42:47): killed process "19915/sync" listening to port 5553.
logger (30.05.2023 18:43:17): databases connected. Update interval 3600 seconds.
logger (30.05.2023 18:43:17): data logger (version 5.4, build 14972) started.
logger (30.05.2023 18:43:17): error (125) while doing bind (port 5553): Address already in use
logger (30.05.2023 18:43:17): process "19915/sync" stalled in "disk sleep".
Any Ideas?
Many thanks
Jochen
HELP! Meteobridge no longer delivering data
jochen.richert
- Fresh Boarder
- Screenshot 2023-05-30 191110.png (79.47 KiB) Viewed 560 times
jochen.richert
- Fresh Boarder
Re: HELP! Meteobridge no longer delivering data
I just added a 32 GB front USB card and station seems to be working. Is there a way to move the old date from th internal staorade to the USB Drive?
Many thanks
Jochen
Many thanks
Jochen
When you give me a remote login (as explained in the FAQ), I can check.
