SIMPLE-UPDATE-WEATHER34-June2023-R3
**important also requires meteobridge device reboot to pick up new API strings
https://www.mediafire.com/file/3do08zc4 ... 3.zip/file
1.adds requested Rain rate day max and time *(important requires new API !! )
2.PHP 8.2.6 VERIFIED
3.modules reduced to original size 190px height..requested
4.new API structure file included in download api-build2023-May.php
rain rate max only appears if there is rain greater than >0(zero) accumulated for the current day
many thanks to Boris for the prompt API update..
Brian
Brian
- jasonmfarrow
Can you confirm that just a Meteobridge reboot (and not a firmware update) is all that is required to bring in the new API strings? Also that the API strings are backwards compaible with all prior Aurora releases?
Regards.
Regards.
hi brian,thanks for the updateweatherist34 wrote: Mon May 29, 2023 8:59 am SIMPLE-UPDATE-WEATHER34-June2023-R3
Brian
I noticed that when it rains and therefore there is a rain rate,the maximum one disappears.Could it be kept visible all the time instead ?? thanks
- Acquisisci schermata Web_30-5-2023_171357_meteoroccamezzomonreale.altervista.org.jpeg (192.61 KiB) Viewed 36151 times
sure we can tweak it to any preference however out of all the stations I have full access too none had any rain when compiling it over the weekend so if you can provide a url for me to collect some data from realtime id be happy to accommodate the request . if not just have to wait till one of the stations has some rainfall then I CAN TWEAK IT..hi brian,thanks for the update
Brian
thanks brianweatherist34 wrote: Tue May 30, 2023 5:40 pmsure we can tweak it to any preference however out of all the stations I have full access too none had any rain when compiling it over the weekend so if you can provide a url for me to collect some data from realtime id be happy to accommodate the request . if not just have to wait till one of the stations has some rainfall then I CAN TWEAK IT..hi brian,thanks for the update
Brian
Another thing I am noticing is that the time of the maximum rate is wrong....
do you need the realtime.txt url ? If yes,how can I send it to you privately?
send it via brian34design "at" icloud.com
thanks I got however there is a problem with the time the API is generating a non recognized string which is not in the request I will have to liaise with Boris end of the week to see if we can resolve .see below the red string generated in the output is not what is being requested
the API string request is [rain0rate-dmaxtime--] but its generating a string output response [rain0!0rate-dmaxtime--] as opposed to a timestamp (example expected 20230529052007) in the MBrealtimeupload.txt .
let you know when its done..many thanks Brian
your MBrealtimeupload.txt output below also similar on others
30/05/2023 19:20:09 18.7 93.0 17.5 0.4 0.9 46.0 0.0 12.2 1014.7 46.0 1 m/s C hPa mm 0.6 1014.4 144.4 540.8 0.0 24.8 48.0 18.7 Vantage 25.4 20230530102706 17.3 20230530060725 54.6 20230530143054 5.4 1.3 1015.4 20230530141610 1013.4 20230530044909 5.6 17.3 0.9 1.4 18.7 -- 12.2 -- 46.0 0.0 19.3 20230530085743 6.6 20230512020620 18.8 20230529171309 19.3 20230530085743 -3.2 20230225042138 -- 94.0 20230530184107 67.0 20230530102804 19.3 20230530085743 14.9 20230530062147 18.9 93.0 17.7 24.7 49 0.2 0.3 -- -- -- -- -- -- -- 88107 26.9 20230529132800 15.8 20230529063305 30.0 20230513142407 11.7 20230505053236 30.0 20230513142407 3.4 20230123035730 7.6 20230529143102 15.2 20230520110137 24.7 20230120110000 0.0 144.4 20230530191835 540.8 20230210035356 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 13.5 20230529063305 141.0 1.3 20230530181145 43.2 20220818132109 3.4 20230123035730 26.4 20220701154021 -3.5 20220414012800 24.7 20230120110000 1015.1 20230529222311 1012.7 20230529154410 1022.9 20230505135111 1000.9 20230520085311 1036.8 20230214091147 999.6 20230225190949 1036.8 20230214091147 997.9 20220331070606 1294.8 20.2 84.3 78.3 14:36 15:30 03:00 1.0 96.0 20230522091201 38.0 20230513160332 96.0 20230522091201 20.0 20230225044505 89.0 20230529052007 53.0 20230529132232 81.0 7.6 70.8 754.0 -- -- -- -- -- -- -- -- [rain0!0rate-dmaxtime--] -- -- -- -- 31.0 3 1 94.0 29.9 20230513141605 -0.4 20230121233046 _Increasing clouds with little temperature change.
Ok,thanks brianweatherist34 wrote: Tue May 30, 2023 7:23 pm thanks I got however there is a problem with the time the API is generating a non recognized string which is not in the request I will have to liaise with Boris end of the week to see if we can resolve .see below the red string generated in the output is not what is being requested
Good morning I found the problem (my typo) with the rain rate day max time have sent an updated API to Boris this morning ..I have implemented the request of showing rain rate max / time
here are the scenarios shifted the rain rate phrase which only appears when it is raining with a rate if no rain you can see the scenarios of no precipitation etc..
..Brian
will push an update when Boris updates the API..
..Brian
SIMPLE-UPDATE-WEATHER34-June2023-R4.zip
https://www.mediafire.com/file/3968v2te ... 4.zip/file
includes rain rate max/time and updated rain rate modules
Boris has updated the API with the fix for rain rate max time string which was my typo error originally ..
this update a meteobridge reboot to pick up the new API ..
HAVE A GOOD DAY Brian...
Good morning
just some open answers to some emails received over the last couple of weeks that may be useful for others ...
1. after the recent API update api has broken the layout on version MB-x5 .
ANSWER:
this version is very old and is no longer supported or fully compatible with the current API or recent API changes over the last year or so.
However I am willing to help on that version where I can has I fully understand why it is still popular with non English speaking users. But support is limited so be aware if the answer is NO its not because I can't be arsed its just not possible.
2.Im using a version Aurora MK II version from January 2021
ANSWER:
Current Simple updates released are only compatible with template version from August 2022 or later anything prior to that date will likely result in a broken layout.
3. API update on Meteobridge devices just simply requires a reboot not a Firmware update.
4. Can I view my Meteobridge data on APPLE WATCH with template ?
ANSWER:
Yes simply DOWNLOAD,INSTALL a third party browser for APPLE WATCH from the APPLE STORE .
Parity is what Ive used over the years on Apple Watch 3,SE,7 and currently works fine on my current ULTRA should not really be much difference between models its simply all about using the latest watch OS... https://apps.apple.com/us/app/parrity/id1448208309
Simply bookmark it and the modules in the layouts appear in single column view and you can scroll down with the crown or swipe up and down to view each module.all themes are fully compatible.
5.Will you ever support Ecowitt additional sensors?
ANSWER: NO Simply have no understanding and neither the enthusiasm to get involved in complex setups that I have simply no understanding of....Sorry Big NO so please don't ask anymore.....
BRIAN...
ANSWER:
ANSWER:
ANSWER:
BRIAN...
SIMPLE-UPDATE-WEATHER34-June2023-R5
https://www.mediafire.com/file/pzwcou3a ... 5.zip/file
Adds dedicated Apple Watch simplified layout with new menu option please set the new setup option to use if required.
this layout also doubles up as a perfect mobile iPhone layout.
compiled using a APPLE WATCH 7 45mm also works perfectly on SE 44mm and Ultra should be no problem on any model with a 44mm screen.
Wow, that looks really great!
It sure is beautiful. Can you also try if you can choose option / screen 6. Here (on an iMac) a number of screens will run together and through each other. Also the update did not work properly. I extracted the update file and reinstalled it that way. Maybe because my last update was in April?
I think everything else has stayed the same...works OK
Bart
Bart
Good morning BartBart wrote: Thu Jun 15, 2023 11:25 am It sure is beautiful. Can you also try if you can choose option / screen 6. Here (on an iMac) a number of screens will run together and through each other. Also the update did not work properly. I extracted the update file and reinstalled it that way. Maybe because my last update was in April?
Bart
think I understand ? are you asking for multiple screen layout simultaneously ? not really a good idea due to multiple resources probably(will) grind your server to a halt has always weather templates request multiple server actions and resources every 10 seconds unlike static websites so not a good idea for those specific reasons (some users do not have efficient servers / hosting packages and many have(low cost solutions) so they generally reduce the upload timing to 60 second updates or more .
update try next time making sure the zip file does not have file permission applied this is quite normal when using a MAC so next time just right click the zip file select Get Info on your Mac desktop or wherever you store it prior to upload and allow all users full privilages .
screenshot below..
..thank you Boris more layouts/themes to come in coming months ...
