I've installed the latest Master, and "SIMPLE-UPDATE-WEATHER34-June2023-R5" but PurpleAir still does not appear to be updating. Their site also shows no API key hits. So far everything else seems to work.
Ok, so I figured out that I had installed the simple update wrong, I did it via manually extracting and pasting over the files, so I decided to do it the right way. So I cleared the pws directory, updated PHP to the latest from 7.4.x to 8.2.8. copied in the master, then installed the latest simple zip using the installer.. For the main page it presents a blank screen. I then went to the console-setup.php page which renders fine and configured everything, saved, rebooted the Pi, still presents a blank page after rebooting.
http://seamanville.com/pws/
Puzzled
Puzzled
I'm assuming I am missing some PHP module
On a good note, I just found the Weather34 Aurora MKII Meteobridge Setup Guide.pdf file
So that question is answered.
Oh interesting, so far it looks like PHP is running fine, but something about 8.2.8 does not get along with the layout.php pages. probably safest to roll back to 8.2.6. But I'll leave it on 8.2.8 for now to see if anyone has any cleaver ideas.
This may be useful;
http://seamanville.com/pws/hello.php
This may be useful;
Update:
I decided to take it back to scratch, a clean install of Debian Bullseye x64 for the raspberry pi. I updated and configured the default PHP on it (7.4.33), and made sure to add Zip this time. I then installed the latest Master from the first page of this forum. For some reason the Weather34 console looks garbled on PC web browser, but looks fine on tablets and phones. I then used the updater to update to the 2022 simple update that ToTo posted the other day (as an incremental until the Sept update is published to solve bugs in the June2023-R5) , then the Jun2023-R5 simple update.
After that I installed PHP8.2.8 along side PHP7.4.33, and set "update-alternatives --config php" to 0 auto.
Once PHP8.2.8 was installed The PurpleAir module started working, tablets and phones look great things appear to be working fine... But PC web browsers are still garbled.
Not sure what I'm missing now.
Wait, looks like it may have been some weird browser caching issue affecting multiple browsers on my system.
Things are looking good.
Nice that you share your progress with everyone here, what was the question again?
Lol, original question was identifying the location of the setup guides since the ones originally posted to the Weather34 site are long gone now. Which then became, anyone have an idea why it would not function with PHP8.2.8 (blank pages).
Hopefully it helps others that may be redeploying their weather stations with a clean install in the near future.
My weather34 setup has been mostly untouched (and running fine) since the time when Brian stepped away from his active role on the project. I recently needed to rebuild mine and happened across this forum. I'm very happy that there is some enthusiast support for this project. I like it and really do not want to move to a different one unless I have to.
I'll understand if my entries are basically clutter for this forum and need to be groomed by a mod.
hello
I will be active in a couple of weeks mid September , i will install a local version of PHP 8.2.9 which i just downloaded https://www.php.net/downloads.php and amongst other things todo .sorry Im not active just a brutal summer here which seems never ending .some relief ahead mid September so hopefully I can sit down and apply some changes , fixes etc.. feel free to ramble on we all benefit from scenarios sometimes its hard to oversee all possibilities so every extra pair of eyes help..
brian ...
brian ...
Hi guys,
I have some problems with the Weather34 admin panel, I updated to the latest version available and I have Php 8.2.8, practically you can't see the images of the layouts, and you can't see the part where the GDPR is, I've also attached pictures.
What could it be due to?
For the rest the dashboard seems to work ok.
https://www.ombarcellonapg.com/wdisplay ... layout.php
- layout.png (48.55 KiB) Viewed 55576 times
- gprd.png (37.28 KiB) Viewed 55576 times
good afternoon
i cant be of much help but I am using 8.3rc which is a later revision than your using https://www.php.net/archive/2023.php#2023-09-28-2
!!! provided some screenshots below .
is there some cache be it browser , server . ?
are there any PHP modules not set ? (often can happen by default on new PHP installs/upgrades)
Im not around much these days to offer any responsive support , I have a unfinished update to complete but kind of enjoying cycling in the cooler outdoor weather
me just chilling out
after the brutal summer.
perhaps others can chime in..
"PHP 8.3 (Upcoming Release)
PHP 8.3, the active development branch, is currently the target for new RFCs (Request for Comments). It is scheduled to be released towards the end of 2023.
PHP has continually evolved to meet the demands of web development. From its origins as Personal Home Page (PHP) to the latest release of PHP 8.2, the language has significantly improved features, performance, and usability.
These advancements have solidified PHP’s position as a top choice for web development, enabling developers to create robust and efficient applications."
I'm checking on the server side if there is cache, while on the browser side any use gives me the same bug.
How do I understand if there are any php modules not set?
A thousand thanks
A thousand thanks
hi
looking closer at your screenshots it just looks a case of missing images .. best thing send me your password to the setup screen i i can see what the error is being logged through the source in the browser ..you can change password at any time ... brian34design "at" icloud.com
Ok thank you!weatherist34 wrote: Tue Oct 03, 2023 2:38 pm hi
hello
as I thought it is just missing images i will try and send them along wednesday via email ..brian
