On all three, this started happening around 10am EDT on 17 August. Two are Ambient Weatherbridges, one is a Pro. Each accesses the Internet via a different provider (RCN, Verizon, Comcast).SFTP Upload: 2023-08-17 19:14:25 Error: 2023-08-17 19:14:22 Couldn't read packet: Connection reset by peer (no more tries):
I suspect something changed on the IONOS end (they are upgrading the Linux currently) that makes something the MB is doing incompatible. However, I experimented with uploading to MacOS and that gave me the same error. Uploads (and downloads) using the Transmit app on a Mac and the command line interface on a Mac work for both cases. So if there is something incompatible it applies to both the IONOS server and the Mac.
I backed down to version 5.6 (edit: 5.5; running 5.6 normally) but it did not make any difference.
Is there any way to turn on some additional debug logging on the Meteobridge to determine what exactly it is seeing? Any other clues as to how to debug this?
