I have created a meta chart for testing, and now I want to delete it. How is this done?
Deleted meta chart. **solved**
Re: Deleted meta chart
Since FW released around August 2023, delete routine is available under System>Administration/Maintenance/Media Access [Download or Delete files] or you can access the file shares directly via SMB
I select the meta chart and press delete, the message that it has been deleted appears, but the file remains undeleted!
Is the file still loaded in any of the Graphs tabs?
The file exists as a name without containing any data
Thanks for spotting this. I tested a bit and it turned out the files that have a space character in their name are not deleted. Reason is that the file name handed over as URL parameter does not get correctly url decoded. I just released an update that should have this fixed.
Re: Deleted meta chart. **solved**
With the last upgrade I deleted the file.
Thanks for the prompt response
