Didi
Post by Didi »
meteolive57290 wrote: Thu Dec 28, 2023 12:41 pm
Didi wrote: Thu Dec 28, 2023 12:15 pm Hello everyone. Excuse my English but I use Google Translate from French.
I have a very basic question but unfortunately I don't know the answer.
I have been using Weather34 for several years but I no longer remember how to display the graphs. For today's chart I put a cron job in meteobridge using the chartstoday.php file. But I can't figure out how to do the other graphs (month and year). If you have any idea on this thank you.
:D salut je te répond en français :D
si tu ne l'as pas déjà fait dans ton MB >Services Settings tu dois aussi configurer une tâche HTTP at 02:00 avec l'URL correspondante :
....pws/weather34-chart-end-of-day.php
bonne continuation
Merci pour la réponse. Le chart-end-of-day vaut pour les mois mais est-il valable pour les graphes années ? As-tu vu ma réponse concernant PurpleAir ? Merci pour ton support.
meteolive57290
Post by meteolive57290 »
weatherist34 wrote: Thu Dec 28, 2023 1:15 pm i have used the ID 47165 and run the stationcron.php . can only say delete the purpleair.txt file and run the stationcron.php manually through your browser your-domain/pws/mbdbfiles/stationcron.php.
double check that API key also ..
i do not have a paid subscription i use the original API key from years ago..
it returned valid data as shown below timestamp converted GMT: Thursday, 28 December 2023 11:10:06
thnx i have checked everything again iD/key and cron which i launched manually as you asked but to no avail the json is still empty ?? or i missed something except the console configuration... sorry :oops:
Didi
Post by Didi »
meteolive57290 wrote: Thu Dec 28, 2023 1:52 pm
A mon avis ton api ne fonctionne plus car Pupleair ont tout monétisé. D'ailleurs lorsque tu utilises leur api payante tu as en réalité deux api. Une en lecture et une en écriture. Si tu commences chez eux tu as le droit à 1'000'000 de points gratuits. En ce qui me concerne cela permet d'utiliser l'api durant environ 134 jours. Après il faut payer..... Dommage pour un produit qui s'est voulu dès le départ collaboratif.
Regarde sur mon site (https://meteolausanne.com/MBSMART2024/w ... tablet.php) tu verras cela s'affiche correctement.
Si tu trouves la solution "gratuitement" fais-le savoir. J'en doute un peu. Belle suite.
hello
try deleting the file purpleair.txt in the jsondata folder and run it manually again
Good afternoon
I have a working demo of new layout Theme 8 at https://whaleybridge-weather.com/weathe ... yout-2.php
if you would like test this and provide some constructive feedback please get in touch . its not ready 100% more likely mid January.
@alex yes supports mmHg
screenshots
Screenshot at Dec 28 16-43-59.png (206.03 KiB) Viewed 365454 times
meteolive57290
weatherist34 wrote: Thu Dec 28, 2023 3:53 pm hello
:oops: systematically it recharges but empty
Capture d'écran 2023-12-28 145735.png (24.31 KiB) Viewed 365453 times
in your browser test this for api return
https://api.purpleair.com/v1/sensors/47165?api_key=put your API key here
this works me see below
Screenshot at Dec 28 17-05-58.png (148.86 KiB) Viewed 365446 times
meteolive57290
:wink: i didn't doubt it for me too, it works except for the template block :?
Capture d'écran 2023-12-28 151439.png (43.04 KiB) Viewed 365442 times
meteolive57290
edit-
by chance could this be a bad file for me ? and on the Meteobridge the Event service [your-domain/pws/mbdbfiles/stationcron.php] still relevant or not at all ? sorry for confused Thnx
meteolive57290 wrote: Thu Dec 28, 2023 4:24 pm edit-
No otherwise you would not see forecast etc send me your API key , i have no use for it other than helping you ..
brian34design 'at' me.com or brian34design 'at' icloud.com
meteolive57290 wrote: Thu Dec 28, 2023 4:18 pm :wink: i didn't doubt it for me too, it works except for the template block :?
file permissions ! if there no data in the file no data gets displayed .. if you complicated server setup or structure then could give you problems
http://valdefench57sgz.franceserv.com/p ... recast.php is also using stationcron.php so if the file was the issue you wouldnt see forecast data . im betting on file permission ! because its blank ..brian
meteolive57290
weatherist34 wrote: Thu Dec 28, 2023 4:31 pm file permissions ! if there no data in the file no data gets displayed .. if you complicated server setup or structure then could give you problems
:oops: usually I use Filezilla for ftp access
screen if I check the authorization compared with pws/forecastcharts/chartforecast.php
where once again sorry if I'm going the wrong way :(-
Capture d'écran 2023-12-28 153554-horz.jpg (92.3 KiB) Viewed 365434 times
not sure i can help , send me the password to your template admin screen you can change at anytime . im curious of something but need to check .
brian
ok i saw it in the email, i placed my PA api key and again nothing so definitely server related to that file , as a test set all permissions on that purpleair.txt file 777 just as a test
then run yourdomain/pws/mbdbfiles/stationcron.php
Theme 8 2024 progress demo at https://whaleybridge-weather.com/weathe ... yout-2.php
any ideas please feel free to suggest got a couple of weeks to try em out..
