woolfg
Post by woolfg »
Hi Brian
Yes I have had to move my website
its at http://ringwoodweather.ddns.net:8000/Weather34/
I dont know if you are able to access it from where you are , username and password are still the same
Warm wishes
Graham
alexeysailman wrote: Sun Jan 07, 2024 9:42 am Hi, Brian! After all, this bug is massive. Even here on the link from the last post.
love your terminology Alexy of late :-) its not a bug or anything wrong its always been like that for a few years(since charts were made smaller . , as the year begins wait 8 days for the dates in chart appear , if you have every date of the year the chart date will become bizzare .. unfortuntely small charts dont allow "massive amount" of dates -:)
see below 8 Jan :-) in year charts .. and another example of using 20 day periods ..has the year progresses it will all fall into shape .
@graham unfortunately not accessible here via ftp/browser or anything I seem to remember this before when you had that url ..
so future updates will have come through your access .
have a good day ..brian
Screenshot at Jan 07 15-27-12.png (147.94 KiB) Viewed 454477 times
Screenshot at Jan 07 15-34-35.png (86.47 KiB) Viewed 454477 times
woolfg
Post by woolfg »
Hi Brian
No problem - thanks for trying
Warm wishes
Graham
xxvincixx
Post by xxvincixx »
HI Brian,I noticed that there is this alignment problem on theme 6 :D :D :D
Acquisisci schermata Web_7-1-2024_184152_meteoroccamezzomonreale.altervista.org.jpeg
Acquisisci schermata Web_7-1-2024_184152_meteoroccamezzomonreale.altervista.org.jpeg (170.09 KiB) Viewed 454453 times
xxvincixx wrote: Sun Jan 07, 2024 7:47 pm HI Brian,I noticed that there is this alignment problem on theme 6 :D :D :D
good morning xxvinc
thank you all fixed , will release update later in the week(thurs/fri) back wednesday but late..
also new theme 9 as requested hope its of use its very balanced :-) live demo at
https://www.paulwilman.com/pw/weather34 ... yout-3.php
your fix below screenshot and theme 9..brian
xxvincixx
Post by xxvincixx »
weatherist34 wrote: Mon Jan 08, 2024 7:25 am
good morning xxvinc
Thanks Brian for the fix,I'm waiting for new theme. Is very beautiful 😍😍😍
lorenz1982
Post by lorenz1982 »
Hi Brian.
"Daylight remaining" error on the theme 7 and 8.
Senza titolo.png (127.12 KiB) Viewed 452977 times
MeteoBorgo: www.meteoborgo.it
woolfg
Post by woolfg »
Hi Brian
I wonder if it would be possible to add a feature whereby you could add a note about the days weather (like a weather almanac) that gets saved away for each day .Maybe a popup window in the menu that opens a small text box
So for example we had a small snowfall yesterday and it would be quite nice to enter it in the days weather
It was just a thought and I dont know how much work would be involved but would be a nice touch
Warm Wishes
Graham
Hello Graham
good idea but not seen any requests for this idea before , with various apps on computers,devices etc i wonder if there is any wider interest.
it is relatively easy to do something basic but often it starts out basic and becomes complex as ideas get thrown around then becomes tedious to maintain ! think template has enough options go any further it becomes difficult to manage..
Lorenzo ive looked at the script which is basically identical to original sun modules etc apart from the css , i made one minor change but I think its related to sun elevation position as the darkness phrase kicks in when sun below horizon or below zero degrees elevation.
anyway its something that needs specific monitoring at the point of transition from daylight to dark but im never around at computer at that specific time.
Simple update January 10th 2024
https://www.mediafire.com/file/nmhuuotc ... h.zip/file
Master https://www.mediafire.com/file/4t58g74x ... 4.zip/file
Adds theme 9 layout less emphasis on circles :-) see screenshot below or demo at https://whaleybridge-weather.com/weathe ... yout-3.php
contains other fixes mentioned in this thread last few days .
.brian
lorenz1982
No problem!
The error occurs both at sunrise and at sunset, only when it should be 0 hours.
It appears 12 instead of 0.
Sorry for my english, see image.
Senza titolo.png (19.27 KiB) Viewed 435809 times
meteolive57290
Post by meteolive57290 »
http://valdefench57sgz.franceserv.com/p ... hboard.php
hello despite the configurations saved in my admin dashboard for location n.8
i cannot correctly display the chosen block (rain_php) :?:
on the following layouts and for the "barometer" block
despite the chosen value (=hPa) all display the variable (=mnHg) while the charts are correct for the unit :!:
here is it by default ...
Thnx and have a good day
Capture d'écran 2024-01-10 093244-vert.jpg (76.24 KiB) Viewed 434464 times
meteolive57290 wrote: Wed Jan 10, 2024 11:11 am http://valdefench57sgz.franceserv.com/p ... hboard.php
you had set to rainmod-2024 /rainratemod-2024.php
rain/rate theme 7 only choose rainmod/rainratemod-full.php ..ive logged in and changed it to full ..
you had use mmhg set to yes , ive logged in and changed it to no ..
..brian...ps please use https://
Screenshot at Jan 10 14-18-59.png (15.92 KiB) Viewed 433040 times
Screenshot at Jan 10 14-20-48.png (48.07 KiB) Viewed 433040 times
meteolive57290
Thanks so much Brian.
Really appreciated.
I’m always humbled by the stuff i don’t know rather than what i think I know :(
ALL’S WELL THAT ENDS WELL :)
BR
Theme 9 is a nice alternative :-) I like it. The temperature and dew point module is currently difficult to distinguish. Maybe change min/max to temperature min/max and dew point min/max.
johnsocal
Post by johnsocal »
When i press backup, it just goes to a blank screen. on the admin page is displayed "locked" at top of page. was trying to backup before applying latest update. using php 8.3.1. last update applied was 2024-R2
