missed Weathernet-Entry for "WLink-Cloud" in actual RPI-Image **solved**
xray77
Post by xray77 »
In the current image for the Raspberry Pi, the entry under weather nets for the Weathlerlink cloud is missing. However, I need this network to upload the MeteoBridge to this cloud.
This weather network is still included in my current MB-NANO-SD, but I would like to switch to the Raspberry MeteoBridge.
Here some Screenshots, first MB Raspberry with the missing Entry for Weatherlink Cloud:
Second MB Nano-SD, here the Entry for Weatherlink-Cloud exists:
I would therefore ask you to integrate this weather network for the MB of the Raspberry as soon as possible, thank you!
best regards, Michael
Is it possible that the WeatherLink cloud weather network is not displayed because my data for the MeteoBridge Raspberry comes from an Envoy8X?
This hardware, does not support the WeatherLink program, i know...
If so, the thread would have been closed.
Re: missed Weathernet-Entry for "WLink-Cloud" in actual RPI-Image
Envoy8X is not supported by WeatherlinkPC or WeatherLink.com. Unless the Raspberry Pi is connected to a compatible Davis system then the WeatherLink Cloud is not an option. Similar to a MBPro connecting to a Davis station via RF, WeatherLink Cloud will not be an option.
xray77
Re: missed Weathernet-Entry for "WLink-Cloud" in actual RPI-Image **solved**
Post by xray77 »
Hello Mattk,
Thanks for your explanation, I almost figured it out... Well, I guess I'll have to find another solution...
Thank you for your help, the thread can then be marked as closed.
Best regards
Michael
