Update help!
Update help!
I'm trying to update my copy of Meteohub from v4.2e to v4.3a but I'm having some difficulty. When I try to open the Meteohub in "My Network Places" so I can put the update in the "/data/transfer/update" path I'm prompted for a user name and password. I've tried using my Meteohub web interface login information but I can't get in. If I remember correctly last time I did an updat I used "meteohub" "meteohub" to get in. Not sure how to update now. Any help would be greatly appreciated. Thank you.
Re:Update help!
Update problem solved but created another. I managed to get the update installed but now I can't connect to Meteohub. Ive tried rebooting my router and rebooting my hardware. I've tried using IPScan and it can't find Meteohub. I tried using the default IP address 192.168.1.77 and still no luck. Any help would be appreciated. Thank you.
skyewright
Re:Update help!
Have you tried to note and use the IP that Meteohub 'announces' via a series of beeps as it starts up?MJC55 wrote:I tried using the default IP address 192.168.1.77 and still no luck. Any help would be appreciated.
