Good day,
I want to import data from meteotemplate, with the precipitation it does not go well and much too little is calculated,
on 02-01-2024 there is 21.8mm in the alldata file after importing, in the Meteobridge database there is 10.8mm
on 03-01-2024 17mm and in Meteobridge 9.6
and so there are many days, on a yearly basis almost 500mm difference.
I am not a hero id writing, hopefully it is clear
meteotemplate ('2024-01-02 23:55:00', '10.0', '10.0', '10.0', '85.0', '7.6', '21.8', '20.9', '256.0', '0.00', '21.20', '980.20', '0.0', ‘5.2’),
Meteobridge 10.8
('2024-01-03 23:55:00', '7.6', '7.6', '7.6', '94.0', '6.7', '4.7', '4.7', '309.0', '0.00', '17.00', '990.30', '0.0', ‘5.9'),
Meteobridge 9.6
Gerrit
import data meteotemplate
Re: import data meteotemplate
you would have to provide your MT export file(s) and your MB import file(s)
then we have a discussion and research base
just ran out of crystal balls ...
The alldata I imported into MB, and an MB export file, I hope it's clear,
especially on 02-01-2024 you can clearly see the difference.
https://waskolkweer.nl/mb.txt
https://waskolkweer.nl/mt.txt
https://waskolkweer.nl/meteobridge
Gerrit
Gerrit
