MBrealtimeupload.txt
pwilman
Post by pwilman »
I have a Nano SD that has been flawlessly uploading to my weather34 template for years. For some reason this afternoon the uploads of MBrealtimeupload.txt became intermittent. They would upload for a few minutes, then were not uploaded and then an empty file would be uploaded. I contacted my host and there was no issue there end. I rebooted MB a number of times and that did not solve the problem.
The only thing that worked was when I swapped over to a spare MB Nano that I had thanks to Brian. I am now using the other MB Nano unit and the uploads are back working perfectly.
Not sure if this is an issue with the Nano or what else it could be?
Paul
Re: MBrealtimeupload.txt
What's the SD card like? capacity?
pwilman
Post by pwilman »
I actually swapped the SD cards over so that I put the one from the not working Nano into the working Nano. There is 48MB free of RAM and 1.6GB free of storage.
Paul
