Installing the VM on Proxmox was no problem, as it was well documented. Many thanks for this.
Question: Why does Davis Vantage Pro2 no longer work via Weatherlink IP, or why can't I select it as a station?
Many thanks in advance for any feedback.
cu.
Zedekia
Meteobridge VM and Weatherlink IP. **solved**
Re: Meteobridge VM and Weatherlink IP
I may need to purchase the license for this, as the Vantage station has an icon for not available?
No trial period issue.
Select Davis Vantage as station and TCP/IP as connection method.
Thank you for your answer.
Yesterday I bought a license.
Everything is working fine. Great job.
Thanks a lot and cu
Zedekia
Thanks a lot and cu
Zedekia
