I can't restore my Meteobridge. **solved**
captgadget
- Expert Boarder
My fan quit working so I tried to install a new fan which doesn't work either. But in the process, I was advised to unplug the Raspberry PI while installing the fan. So I backed up the Meteobridge. I plugged it back in and when I try to reinstall my Mac says it can't open the page. But this is the message I get in my Meteobridge. WARNING: 1 event definitions have been converted into a new format. Event definitions will be no longer visible/operational when you switch back to an older Meteobridge version. When you switch then back to a newer version event definitions will appear again. It is recommended to immediately go to "System - Administration" tab and store old configuration data with "Configuration Data -> Backup" option onto your PC. Press "Save" on "Services - Events" tab to clear this message. What's all this mean and what do I have to do?
captgadget
- Expert Boarder
