Got a new Reolink RLC-811WA **solved**
- Expert Boarder
And I would to share the photo on Meteobridge but I don't have a clue how fill in the blank with the correct information. Galfert helped me set it up for my old Foscam but he's bowed out so now I'm lost.
- jasonmfarrow
Re: Got a new Reolink RLC-811WA
You'll need the IP address of your FOSCAM and you'll need to either use the Admin account or make a USER account. Then you can use the API with something like this in the URL on the Meteobridge Weather Cam page:
It helps to have your Foscam given a static IP address from your router. It avoids having to change the Meteobridge in case you have to reboot the cam.
You can test if it works by inserting your completed URL into a browser. If it returns a .JPEG then it will work in your Meteobridge
http://your_Cam_IP_address:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=your_ID&pwd=your_Password
- Expert Boarder
I'm sorry but I'm no longer using the Foscam but a Reolink RLC-811WA. That's the one I need help with. Thanks anyway
- jasonmfarrow
There is a similar API for Reolink.
The documentation is here: https://support.reolink.com/hc/en-us/ar ... o-CGI-API/
You are looking for section 3.6.7 - Snap: where the command is something link this:
Refer to this page for examples: https://support.reolink.com/hc/en-us/a ... -Browsers/
Note: HTTPS is the default. If you need HTTP then you need to enable it in the Reolink Settings as per section 2.1
Let us know if you were successful
https://192.168.1.238/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=flsYJfZgM6RTB_os&token=TOKEN
- Expert Boarder
I followed the steps in this post exactly as they are written and the camera works pertly! https://www.wxforum.net/index.php?topic=38929.25
- Expert Boarder
I don't know how to mark Solved so if the moderator would help go right ahead. Thanks
