After reboot, everything is lost. No database anymore, and only errors in the log.
The last messages only repeat.oled (22.12.2024 12:19:00): process started.
test5m (22.12.2024 13:20:01): weathernet daemon stalled, will be restarted now.
wnetd (22.12.2024 13:20:01): process started.
test5m (22.12.2024 13:20:01): logger stalled, will be restarted now.
wnetd (22.12.2024 13:20:01): send data thread started (pid:1697 tid:1699)
system (22.12.2024 13:20:01): stop of logging process initiated.
setup (22.12.2024 13:29:10): use UTC stamp 2024-12-22 12:29:10 (1 tries)
dbrepair (22.12.2024 13:29:19): database size is .
dbrepair (22.12.2024 13:29:19): test integrity of database.
dbrepair (22.12.2024 13:29:19): database integrity is fine, but rebuild is forced.
dbrepair (22.12.2024 13:29:19): not enough free space to repair database.
dbase (22.12.2024 13:29:21): process started.
dbase (22.12.2024 13:29:21): database sync done (0 tables, 0/0 writes).
system (22.12.2024 13:29:24): start of logging process initiated.
logger (22.12.2024 13:29:24): databases connected. Update interval 3600 seconds.
logger (22.12.2024 13:29:24): data logger started.
logger (22.12.2024 13:29:26): connect station 0 (Meteostick Vantage via USB serial).
logger (22.12.2024 13:29:26): connect station 1 (AirLink via SW Driver).
logger (22.12.2024 13:29:26): connect station 9 (System Data via Plug-in).
logger (22.12.2024 13:29:26): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (22.12.2024 13:29:26): services paused.
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), transmitter 1 registered as ISS
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), transmitter 2 registered as Soil
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), transmitter 3 registered as Wind
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), Meteostick Version 2.5.2
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), debug off
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), verbose off
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), output raw (8 bytes)
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), output raw (10 bytes)
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), filter on
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), rx threshold set to -90db
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), listening to transmitter 1 2 3
logger (22.12.2024 13:29:27): station 0 (Meteostick Vantage), bandwidth narrow
logger (22.12.2024 13:29:28): station 0 (Meteostick Vantage), chip authentication ok: 14
logger (22.12.2024 13:29:28): station 0 (Meteostick Vantage), frequency band 868MHz (EU)
dbase (22.12.2024 13:30:00): cannot create table (after 0 tries in 2ms): database or disk is full (13)
dbase (22.12.2024 13:30:00): cannot commit (after 0 tries in 1ms): cannot commit - no transaction is active (1)
dbase (22.12.2024 13:30:00): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
dbase (22.12.2024 13:30:00): cannot prepare select on update table 'wind1dir_hour' (after 0 tries in 1ms): no such table: wind1dir_hour
dbase (22.12.2024 13:30:00): rollback on insert forced (2) (hour): wind1dir
dbase (22.12.2024 13:30:01): cannot create table (after 0 tries in 1ms): database or disk is full (13)
dbase (22.12.2024 13:30:01): cannot commit (after 0 tries in 1ms): cannot commit - no transaction is active (1)
dbase (22.12.2024 13:30:01): cannot rollback (after 0 tries in 1ms): cannot rollback - no transaction is active (1)
dbase (22.12.2024 13:30:01): cannot prepare select on update table 'wind1dir_hour' (after 0 tries in 1ms): n
I tried to delete the database, do a rebuild etc. No luck.
In Luci I do not see any database space enabled.
What to do next ?
As you can see both are NOT Enabled.Mounted file systems
Filesystem Mount Point Available Used
rootfs / 4.93 MB / 9.13 MB 46% (4.20 MB)
/dev/root /rom 0.00 B / 5.50 MB 100% (5.50 MB)
tmpfs /tmp 18.48 MB / 25.00 MB 26% (6.52 MB)
/dev/mtdblock5 /overlay 4.93 MB / 9.13 MB 46% (4.20 MB)
overlayfs:/overlay / 4.93 MB / 9.13 MB 46% (4.20 MB)
tmpfs /dev 0.00 B / 512.00 KB 100% (512.00 KB)
tmpfs /tmp/mnt 0.00 B / 512.00 KB 100% (512.00 KB)
Mount Points
Mount Points define at which point a memory device will be attached to the filesystem
Enabled Device Mount Point Filesystem Options Root Check
UUID: d9ba-6b1d /mnt/sda1 ? defaults no no
UUID: 68cda153-70d6-4870-bbcb-1bdd40dbc174 /mnt/sdb ? defaults no no
