I installed the sensor in the roof but I can't get wind speed and uv index values. I can't see the values on the screen. But other values like temperature, pressure can be seen correctly.
What can be the reason of this problem? How can I solve it?
OREGON WMR100A (wind speed problem)
skyewright
Re:OREGON WMR100A (wind speed problem)
Does the WMR100 console see the wind & UV?gulec wrote:I installed the sensor in the roof but I can't get wind speed and uv index values. I can't see the values on the screen. But other values like temperature, pressure can be seen correctly.
skyewright
On my consoles (WMR200 & WMR928) the wind would show as -- if the sensor was out of range; but if the anemometer is turning and you are still seeing 0.0 then it does sound like a reception problem.gulec wrote:Only thing I can see is ZERO for wind and UV values on the console. There must be some transmission problem from sensor to console. I attached the picture of console maybe it can help.
If you temporarily move the console nearer to the sensor do you start getting a sensible reading?
David
I did exactly what you said. I moved the console closer to the sensor but nothing. I couldn't read any value again. And annemometer is turning. So what can be done if there is a reception problem? Thanks.
skyewright
The first thing would be to try resetting the console. Have you tried that?gulec wrote:I did exactly what you said. I moved the console closer to the sensor but nothing. I couldn't read any value again. And annemometer is turning.
David
Yes I did it I reset both sensor and consol but nothing changed. :S
