Problem with ionos sftp
zapal
Post by zapal »
Good morning everyone from Spain. I am having problems with SFTP on my 2 meteobridge pro2 dataloggers. Both work fine for 1 or 2 days and then they stop uploading the template to the inonos sftp server where I have them configured, the part that uploads information to the meteobridge website works without problems.
Once I restart them everything works again, but I don't know how to correct that problem. I have several more stations with rpi+weewx and they don't give me this specific problem with ionos via sftp.
I've been looking at the photo but it seems like no one has the same problem... lucky for them :-D
Thank you
Plataforma: Meteobridge PRO2 *
RAM: 123 MB total, 29 MB Libre (76% usado)
Almacenamiento: WD SLC, 14.7 GB total, 14.1 GB free (4% usado, 30.2 yrs)
Versión SW: Meteobridge 6.1 (Jan 30 2025, build 5678), FW 1.3
Tiempo de actividad: 2 Horas, 15 Minutos Buffer: 1 Items (0%)
Datos de energía: 5.21V 227mA 1.19W (Clima Box: 29.9°C 32%)
zapal
Re: Problem with ionos sftp
Post by zapal »
Good morning, you set up an sftp server on a machine and the error occurs, after hours or days it stops uploading the configured templates to the sftp. The Weather34 dashboard is working normally. If I do a "sftp test" it uploads the test file without problems, but it does not upload the others at the default interval. When I restart everything works again.
Could someone tell me how I look at the logs of that task in the meteobridge?
thank you
Can you please give me a remote login?
It might be that you have services with very short repeat intervals defined and by that the queue fills up over time and finally stalls. You can inspect queue status on "System - Info" tab. You also can inspect upload traffic on "Monitoring - Upload status" tab.
