I suspect I know the answer to this...but I need to know for sure.
I am currently operating a Peet station in a remote location and using the WXTrak interface (Byonics.com) to send APRS data via Amateur Radio. System is working great...data is being fed into the whole APRS system.
I have since discovered WD Live and really would like to try and interface it to my data and display it directly on a website. My problem is that I am operating from a REALLY remote location via solar power...no possibility of Internet access unless somehow possible via my radio link and that I do not want any intermediate PCs required in the loop. I think the Meteohub *might* be able to play into this somehow.
1) Is the Meteohub package absolutely dependent upon a direct Internet connection?
2) As long as proper credentials are supplied...can it FTP the data directly to my website without any intermediate hardware in the loop?
Any ideas as to how I could make this work?
Remote Data Feed for WD Live
skyewright
Re:Remote Data Feed for WD Live
It will run fine with no network present.RCurtis wrote:1) Is the Meteohub package absolutely dependent upon a direct Internet connection?
You can't just plug it into a phone line, if that is what you mean?2) As long as proper credentials are supplied...can it FTP the data directly to my website without any intermediate hardware in the loop?
To reach you server it would need a network connection of some sort.
David.
Sorry...I guess I did not elaborate enough as to my installation. I understand that you can't plug it into a phone line...that would be nice! When I said I was operating from a remote location...I mean REMOTE! Solar power, no infrastructure at all. My only link to the outside world is the APRS Amatuer Radio link.
Given what you've said, my question now becomes "If I don't use the APRS protocol for outbound transmission...how would I get my data to the Internet?"
Hi from Italy.
Can I have a little help to connect my WXtrak with Ultimeter 800 ???
What are the propers connections between wx trak and peet bros ???
Thanks for the help,
Stefano
Stefano
