Meteohub Update 4.4
What's hot...
Meteohub Update 4.4
DEUTSCH:
Update V4.4 (NSLU2 und x86) enthält die folgenden Änderungen:
* Erweitert die Nutzungsperiode als Demoversion auf den 31.8.2009.
* Reduziert die Ausgabe von Meldungen in der Protokolldatei "system log".
* Unterstützt bei WD-Live in Verbindung mit einer Vantage mit Solarstrahlungssensor die Ausgabe der Evotranspiration.
* Alarmfunktion detektiert nun wieder Sensoren mit geringem Batterieladestand (lowbat) und nicht empfangene Sensoren (failed).
* Verbessert die Zuverlässigkeit von WS2300 Sensordaten durch wiederholtes Auslesen und Vergleichen von Daten.
* Verbesserungen beim Wiederaufsetzen von USB HID-Devices.
ENGLISH:
Update to Meteohub V4.4 (NSLU2 and x86) brings these features:
* Sets end date for demo period to 31th of August 2009.
* Reduces messages recorded in log file "system log".
* Fixes a bug on reporting WD_Live "evotranspiration" for Vantage stations with a solar sensor connected.
* Improves reliability of WS2300 sensor readings by comparing consecutive data transfers.
* Updates alarm capabilities for lowbat and failed sensor conditions.
* Improvements for restarting USB HID devices.
Update Link: http://www.meteohub.de/joomla/index.php ... &Itemid=29
NSLU2 USB Stick Image 4GB: http://www.meteohub.de/joomla/index.php ... &Itemid=29
NSLU2 USB Stick Image 2GB:
X86 Installation USB Stick Image:
cbhiii
Re:Meteohub Update 4.4
Post by cbhiii »
Just updated to v4.4. Doing recomputation now and it says that Rapidfire is running, yet it is not working. Been over an hour since last rapidfire update received at WU.
No regular updates to WUnderground either since reboot and recompute started. Should come every 5 minutes, but nothing for over an hour. Image
When data logging has halted, rapid fire has nothing to report.
So main question is, why is data logging halted?
cbhiii
Post by cbhiii »
Where does it say that? It says running. I'll look into the system further.
Update:
I find no defect in programming. I will reboot.
Sorry, my fault. But it is not receiving any data. So nothing to report via Rapid Fire.
cbhiii
Post by cbhiii »
Okay, I agree. Reboot did not help.
If you have a moment can you take a look (I'll email you). Before update it was running solid for nearly 30 days.
I tried starting and stopping logging, but it does not work. Only step left I think it to power cycle the eBox.
bjcatlin
Post by bjcatlin »
I updated to 4.4, and I now seem to have my monthly rain totals reset to 0 each day. After 3 days of rain storms, my monthly and daily rain totals are exactly the same. When I looked at it last night, both the monthly and daily rain totals reset to zero just after midnight. Could this have been due to the change for evapotranspiration?
This is on a NSLU2 attached to a Vantage Pro II plus (with solar and UV, but no leaf wetness or soil moisture sensors).
cbhiii
Re:Meteohub Update 4.4 System Log
Post by cbhiii »
Boris,
Since v4.4 upgrade the system log has been stuck on my system on July 6. It no longer seems to be updating. This was a problem on past versions, but it was working on previous version.
Feel free to take a look at my system if you'd like. I can email you again or look for email from Huffman for access that I previously sent.
Thanks!
