PHP file size limit was lifted by me from 2MB to 200MB. Uploading larger archives should now work fine. I also modified the PHP timeout to allow for scraping larger weather data with the "clone" option. Hopefully, this renders the solution now valid for even larger installs.
Cutting a large archive into yearly chunks and importing those is also a clever work-around.
I am just making myself a bit more familiar with PHP by taking over the Aurora project. Next update cycle will hopefully go a bit smoother ;-)
Please continue reporting issues in this thread. Thanks.
pwilman
Post by pwilman »
Boris,
A quick suggestion - could you add in a question in the console-setup window to allow the user to select the default theme colour for the dashboard (dark or light). There is a question to select the colour of the background the graphs, but not the overall dashboard.
I like the light theme colour, but it often reverts to dark when I do a refresh.
Just an idea.
Paul
lorenz1982
Post by lorenz1982 »
In theme 9 "Display Notifications Alerts" does not work.
In other themes it works.
Immagine 2025-05-12 141025.jpg (7.98 KiB) Viewed 10798 times
Immagine 2025-05-12 141314.jpg (7.8 KiB) Viewed 10798 times
MeteoBorgo: www.meteoborgo.it
Just updated the Theme 9 chart, please give it a try.
lorenz1982
It works, thanks.
Updating with the cloud is very convenient.
pwilman
Post by pwilman »
Boris,
Not sure if its relevant, but I seem to have had 3 instances at 14th May added to the graphs. All with exactly the same data. Dont think I have done anything. Does not bother me majorly, but thought I would report it just incase there is a bug somewhere that others experience.
If you have a look at www.paulwilman.com you can see my cloud dashboard and if you click on the extra data button for any of the variables you will see what I mean. I have not noticed this before.
Paul
lorenz1982
I noticed something, I had never noticed it before.
The pressure value never changes colour, unlike other values.
Suggestion for next update if possible.
Immagine 2025-03-12 095100.jpg (60.08 KiB) Viewed 10406 times
Immagine 2025-03-12 095129.jpg (35.47 KiB) Viewed 10406 times
pwilman
Post by pwilman »
Boris,
Same thing happened to me today....I have 3 occurrences of data for the 15th May as well. Thats 3 x 14th May and 3 x 15th May?
Paul
ok, will have a look.
Installations not under current data upload operations should be fine. I cleaned up double entries and if needed will run that on a daily schedule.
pwilman
Post by pwilman »
Boris,
Thanks for looking into this....just checked my cloud dashboard
https://content.meteobridge.com/dashboa ... yout-3.php
and the triple entries for the graphs are still there?
Paul
pwilman wrote: Fri May 16, 2025 4:21 pm Thanks for looking into this....just checked my cloud dashboard
should be good now
pwilman
Post by pwilman »
Boris,
All good - thank you for sorting this out. Do you know what happened and whether anyone else has reported the issue?
Should I message if it happens again?
Paul
It can happen when files are uploaded and the marker for last day that has been charted is overwritten. I will run a regular job so it should solve itself.
pwilman
Post by pwilman »
Boris,
Big thank you from me for sorting this.
Paul
par
Post by par »
Dobrý den.mám takový problém,když kliknu na meteobridge aurora tak se mi objeví chybová hláška HTTP ERROR 500,jak to vyřešit?
