Importing data into Access
D70
Post by D70 »
Hi folks!
I want to import all the data collected by Meteohub to an MS Access Database.
As first approach I'm trying to import WD Export Files generated by Meteohub and then import into Access. My first issue arises with the precipitation data. If I understood the data format of WD File the 13th column refers to precipitation. After the first import I've run a query for January (summing all the precipitation column for that month) and I've got 230mm but in WUnderground my Meteohub as reported 322 mm of precipitation!! It's very disparate values... What may be the problem of this differences?
In the ~/meteograph.cgi?text=all output for January I've got 230 mm too. Thus, it seems that WUnderground it's doing wrong calculations... Anybody can confirm this discrepancies?
Best regards!
