Aurora 2026 Rev-4.4Q Release
pwilman
Re: Aurora 2026 Rev-1T Release
Post by pwilman »
Just updated to the latest version and in chrome I am seeing some very minor alignment issues. Cells 18, 19 and 20 from my website (www.paulwilman.com/W34) the various images seem to touch the top of the cels. Suspect its a chrome issues
Paul
Re: Aurora 2026 Rev-1T-2 Release
pwilman wrote: Sat Feb 28, 2026 10:36 pm Brian,
Paul
Good morning as always many thanks try this ..screenshot of chrome on Mac below
Download Master Aurora-2026-REV-1T-2
https://www.mediafire.com/file/jehodk21 ... 2.zip/file
Download Simple-Update-Aurora-2026-REV-1T-2
https://www.mediafire.com/file/mi5wz5xr ... 2.zip/file
Screenshot 2026-03-01 at 06.03.44.png (1.11 MiB) Viewed 1330 times
Feb 22- 1st March Aurora 2026 Rev - 1T-2
1. Added large clock module ..requested
2. Fixed today charts showing purple air if set to NO in setup .requested
3. Fixed year charts showing month data when clicking icon for larger view .requested
4. Added last updated time for Offline Notification ..requested
5. Verified PHP 8.5 release compatibility ..requested
6. Cleaned and Simplified Setup Login page
7. Reworked setup screen css for easier implementation of new ideas/custom modules
8. Cleaned out unused code for 232 PHP files !!
9. Added new Aurora 2026 icon
10. License module reworked to reflect meteobridge hardware in use
11. Fixed not showing correct image for meteobridge pro models
12. If your PHP version in use is less or lower than PHP 8 you will see a PHP required upgrade message in setup login screen
13. Added alert icon to fire risk , heat-index , earthquakes
14. Re compiled chart layouts in dashboard modules
15. Optimized light theme for IOS devices
16. Added caution icons when threshold of high or below is met examples dew point is above 21c or 69F or low humidity below 20%
17. Added support for Apple Watch Ultra 1/2/3 and series 9-11 .* note main page only !! simplified menu & sensor view..
18. Added new icons for majority of modules
19. Recompiled Webcam script
20. New FAVICON for browser etc
21. Fixed local Metar temperature color
22. Fixed WU forecast temperature color
23. Fixed non metric(F) temperature ICON
24. Fixed Chrome Browser alignments in small bottom modules
25. Adds ANDROID and Microsoft tablet compatiability
Todo
..custom module how to use and configure meteobridge PDF
.. Android phone compatibility
pwilman
Post by pwilman »
Thanks Brian - all sorted on the alignment.
Just spotted another one on the wind module - when the direction is "South" it slightly protrudes out of the circle.
Paul
Re: Aurora 2026 Rev-1U Release
pwilman wrote: Mon Mar 02, 2026 9:44 am Thanks Brian - all sorted on the alignment.
Paul
Good evening Paul
thanks all fixed ..
Download Simple Update Aurora 2026 Rev 1U https://www.mediafire.com/file/rx68uvf1 ... U.zip/file
Download Master Aurora 2026 Rev 1U https://www.mediafire.com/file/i98qgt9y ... U.zip/file
1st-2nd March 2026
1.Added Windchill small module
2.Added Heat Index small module
3.Added Alternative weather forecast small module (now 2 options for small forecast modules)
4.reworked all small modules
5.reworked all charts in main page
6.Fixed Wind Direction North,East,South,West wording position ..ref Paul
7.added new temperature icon where temperature based values used i.e feels
8.corrects all conversions to F where error was present
Screenshot 2026-03-02 at 17.33.45.png (480.24 KiB) Viewed 1282 times
Screenshot 2026-03-02 at 19.21.16.png (403.06 KiB) Viewed 1282 times
Re: Aurora 2026 Rev-1U-2 Release
Download Simple Update -Aurora-2026-1U-2 https://www.mediafire.com/file/wvake22t ... 2.zip/file
Download Master Aurora-2026-Rev1U-2 https://www.mediafire.com/file/z70jgch4 ... 2.zip/file
1.icons positioning unified in small modules
2.fixes windchill format and threshold
3.aligns small module captions
4.adds unit to module caption
5.corrects Luftdaten PM10 not showing
6.corrects Air Quality Icon coloring to match expect color value
7.corrects Time appearance in small module
8.Safari/Chrome checked ! :-)
Screenshot 2026-03-03 at 12.57.07.png (476.29 KiB) Viewed 1162 times
Screenshot 2026-03-03 at 12.59.19.png (416.81 KiB) Viewed 1162 times
pwilman
Post by pwilman »
Just updated to the latest version...thanks for making all these tweaks.
Quick question - there seems to be quite a large gap between the control icons on the left had side (settings, metar, forecast etc) and the start of the cells. Is there a reason for having such a big gap or could you move the icons closer to the cell margins and reduce the page width?
Paul
lorenz1982
Post by lorenz1982 »
Good morning, I just installed Aurora 2026 and loaded the data from 2021.
Why don't I see 2021 in the console charts?
Also, the Airlink max data is missing for 2025 and 2026.
MeteoBorgo: www.meteoborgo.it
pwilman wrote: Tue Mar 03, 2026 2:57 pm Brian,
Paul
need a gap for NON METRIC to allow 100F or more values to align and to compensate for other devices not all display margins the same ..
example
Screenshot 2026-03-03 at 16.16.50.png (485.67 KiB) Viewed 1143 times
lorenz1982 wrote: Tue Mar 03, 2026 3:11 pm Good morning, I just installed Aurora 2026 and loaded the data from 2021.
hello I look at it for next weekend release enough updates for this week already .. don't worry ill sort it out:-)
pwilman
Post by pwilman »
Morning Brian,
Couple of tiny things I have noticed:
- the feel like temperature in the main internal house cell (unit 12 on my install) is all superscript, including the temperature.
- the current closest earthquake to me says 147 miles from Bath in the small bottom cell, but if you click on the earthquake icon from the side menu that says the same earthquake is 237 miles from Bath
I really am finding the minute detail things now, in particular the EQ measurement one!
Paul
johnsocal
Post by johnsocal »
p13 small clock has overlap of sunrise/sunset with time, p14 has overlap of temp from p16
I miss having the current time and time since last updated at the top of the page...
Screenshot 2026-03-04 at 11.14.50 AM.png (155.32 KiB) Viewed 1094 times
johnsocal wrote: Wed Mar 04, 2026 8:18 pm p13 small clock has overlap of sunrise/sunset with time, p14 has overlap of temp from p16
Good morning
many thanks really appreciate the feedback etc ,for the clock issue my fault for not checking use of 12 hour time am/pm format output so fixed , also the forecast issue is when you run both forecast modules one knocks out the css for the other so recompiled those to use separate css .see below , your 56 years ago in the updated data online module is likely down to your path settings in the setup screen your probably using a url http/https:// etc or it maybe server config to read timestamps can't really help on that but basically 56 years ago is common when url paths are use instead of server path .
@Paul all fixed overlap of a css and the eq distance formula was not correct in the small module so corrected that to match .
will push simple update at weekend ..Brian
for the clock at the top I added a new option to show clock at the top of dashboard tot the left .simply a yes or no option ..Brian
lorenz1982
Just a few small oversights.
Some pages of the graphs are missing the "Solar Max" data, and there's this error on today's graphs page:
Immagine 2026-03-05 084949.jpg (4.65 KiB) Viewed 1070 times
Thanks for all your work.
lorenz1982 wrote: Thu Mar 05, 2026 9:50 am Just a few small oversights.
Thank You ... fixed and please note this version of template AURORA 2026 does not support chart data prior to 2021.. some will remember the chart structure and format prior to 2021 was very limited. 2021 charts were recompiled and additional quite a few different data points were added .
sorry whilst the data is there in a limited structure is just too much work to run different formats of chart data to accomadate before 2021 . so 2021 is the limit for previous years.
shows fixed and menu for 2021 to current year and fully supported up to year 2030
