meteocam to weathercloud. **solved**
alexvanuxem
- Senior Boarder
Hi all,
There's a new version of weathercloud (v14) where you now can ftp your weathercamera pics.
In MB i have a cam installed as device (ecowitt hp10), but to be able to send the pics to weathercloud I need to ftp to theire server with a user id, and password.
This is the how to https://weathercloud.net/nl/compatibele ... /ftpwebcam
How to do this with MB? in services, events, ftp upload, I can not specify a server, user, or password?
Alex
Alex
alexvanuxem
- Senior Boarder
Re: meteocam to weathercloud
Thanks, but I already entered a FTP service to FTP my personal 'public_html' websites....
Or can I have second, probably not.
Can please elaborate?
thanks
Alex
thanks
Alex
You can have a second FTP service. Access the service tab add FTP then select your event type and put the credentials in the Path as explained in the wiki:
“When you want to upload data to another FTP server, you can use a fully qualified URL-like FTP notation in the "Path" field. Format of the FTP URI has to be: ftp://user:password@host:port/path.”
If I understand you correctly you have a camera sending snapshots to MB and you want to take the snapshots sent to MB and send to weathercloud..you would also need to configure to grab those snapshots from MB so you can send weather cloud.
g
g
I'm in the same situation, but it was told to me that ftp on the MB can only be used to transfer data, no jpg 's.In MB i have a cam installed as device (), but to be able to send the pics to weathercloud I need to ftp to theire server with a user id, and password.
So I also look forward for a solution.
Correct me if I'm wrong.
LD
alexvanuxem
- Senior Boarder
hi I'm using FTP Cam in the service events, very 5 minutes to ftp://XXXXX:XXXXX@ftp.weathercloud.net:21/webcam.jpg
but the monitor upload status says : 2026-04-06 10:41:12 Error: 2026-04-06 10:40:31 Server hungup immediately after connect. Server hungup immediately after connect. Server hungup immediately after connect. ncftpput: cannot open ftp.weathercloud.net: could not connect to remote host, but can try again. (no more tries):
I have partial succes with a script on my raspiberry pi, where i first download the webcam.jpg from the MB cloud, and then send it to weathercloud.
Works often, but not always.
Maybe the @admin can help?
Cheers
Alex
Cheers
Alex
alexvanuxem
- Senior Boarder
i've made a sript to upload your webcam from meteobridge to weatgercloud (pro users only)
fill in your user and password id, and the cloud webcam url from meteobridge.
trigger the script in events, every 5 minutes.
you can monitor the log when you ssh to root@ipadress of MB and do cat /var/log/upload_wc.log
it works with me,
have fun
alex
it works with me,
have fun
alex
Looks very interesting !
I now have a webcam.sh script running on a Raspberry Pi. It works, but only with a successful rate between 35 - 40 %
I'm not a Meteobridge expert, so can jou please say how and where I have tot put the upload_wc.sh file on the Meteobridge (running the last firmware)...
And is ncftpput always active on the MB?
Many thanks!
LD
Many thanks!
LD
alexvanuxem
- Senior Boarder
hi,
It's not 100% succes rate, at random it fails, maybe 70% succes rate?
I guess it's at their side, if their server gets overloaded? I have sent them a message to explain.
One thing I forgot to mention, you need to use the http url not https of your cloud webcam url.
You make on your pc a network link to the MB, once made, when opening the link, tou will see a data folder of your MB? place the file there.
In the gui of the MB, go to services, events, add script event, choose periodical, reload scripts, choose script, add 5 minutes period, and save, you can test the script using the test button.
Then you can monitor also on monitor, upload status.
cheers Alex
cheers Alex
Thanks, I'm still having some problems implementing the script:
2026-04-08 17:52:09 - Snapshot Download Succes: /tmp/webcam.jpg
2026-04-08 17:52:09 - Start upload passive mode
ncftpput: cannot open 5.175.47.188: could not connect to remote host, but can try again.
2026-04-08 17:52:09 - Passive mode failed, try active mode
2026-04-08 17:52:09 - Error uploading to Weathercloud! rc=1
2026-04-08 17:52:09 - Script ended
don't know where is the fault.... perhaps ncftpput is not active on my Meteobridge ?
LD
LD
alexvanuxem
- Senior Boarder
hi I have that sometimes too, let it run for a day.
has it always failed?
to see if you have ncftpput in the root@ip of MB type which ncftpput. If you have ncftpput it should say something like usr/bin/ncftpput.
i used the 5.175.47.188 as it is adress of ftp.weathercloud.net server. in my testing it starting working when I cahnged to that.
But maybe i was too impatient?
I will test that asap (change to ftp.weathercloud.net).
First keep running please, and tell me the outcome? So we can finetune the script?
cheers
Alex
cheers
Alex
Thanks!
For the moment, I looked somewhat better at my own uploads (Raspberry Pi script and normally every 4 minutes). But I find a bit of a strange behavior... Every upload at 8 - 12 - 16 - 20 and 24 minutes is successful. And then it fails, till the next hour. Hence my success rate around 33 %
This is consistent behavior over several days. I now set the interval at 10 minutes, see what is the result ...
LD
LD
alexvanuxem
- Senior Boarder
yes you are right, same here actually.
They promised every minute is accepted.
also asked Boris of meteobridge for input.
Can you share your rapi pi script?
thanks
Alex
thanks
Alex
Very strange, in the '10 minutes interval schedule: only this ad 10 and 20 minutes are successful....
Hereby my webcam.sh script:
#!/bin/bash
export PATH="/usr/bin:/bin:/usr/sbin:/sbin"
# ==== CONFIGURATIE ====
# Camera gegevens
CAM_IP="192.X.X.X"
USER="a"
PASS="b"
# FTP gegevens (Weathercloud)
FTP_USER="c"
FTP_PASS="d"
FTP_SERVER="ftp.weathercloud.net"
# Paden
SCRIPT_DIR="/home/ld/webcam"
IMG_DIR="$SCRIPT_DIR/images"
IMG_FILE="$IMG_DIR/latest.jpg"
DEBUG_LOG="$SCRIPT_DIR/debug.log"
WEB_COPY="/var/www/html/blog/fotos/foto4.jpg"
# ==== UITVOERING ====
echo "=== $(date) ==="
echo "Running as user: $(whoami)"
echo "PATH: $PATH"
# Zorg dat de images-directory bestaat
mkdir -p "$IMG_DIR"
echo "
Snapshot maken vanaf camera..."
/usr/bin/curl --silent --digest --user "$USER:$PASS" "http://
$CAM_IP/axis-cgi/jpg/image.cgi" -o "$IMG_FILE"
SNAP_EXIT=$?
echo "Camera snapshot exit code: $SNAP_EXIT"
ls -lh "$IMG_FILE"
# Controleer of het beeld goed werd opgeslagen
if [ ! -s "$IMG_FILE" ]; then
echo "
Fout: snapshot mislukt of leeg bestand."
exit 1
fi
echo "🗂 Kopie maken naar intranetfolder..."
cp "$IMG_FILE" "$WEB_COPY"
COPY_EXIT=$?
echo "Kopie exit code: $COPY_EXIT"
ls -lh "$WEB_COPY"
sleep 10
echo "
Uploaden naar FTP (Weathercloud)..."
# FTP upload met retries
TRIES=3
for i in $(seq 1 $TRIES); do
/usr/bin/curl --silent -T "$IMG_FILE" --user "$FTP_USER:
$FTP_PASS" "ftp://$FTP_SERVER/"
UPLOAD_EXIT=$?
echo "
FTP poging $i, exit code: $UPLOAD_EXIT"
if [ $UPLOAD_EXIT -eq 0 ]; then
echo "
Upload geslaagd bij poging $i"
break
else
echo "⚠ Poging $i mislukt, opnieuw proberen na 30
seconden..."
sleep 45
fi
done
if [ $UPLOAD_EXIT -ne 0 ]; then
echo "
Upload is na $TRIES pogingen mislukt"
fi
echo ""
} >> "$DEBUG_LOG" 2>&1
#!/bin/bash
# Camera gegevens
CAM_IP="192.X.X.X"
USER="a"
PASS="b"
FTP_USER="c"
FTP_PASS="d"
# Paden
echo "PATH: $PATH"
mkdir -p "$IMG_DIR"
echo "
SNAP_EXIT=$?
ls -lh "$IMG_FILE"
echo "
exit 1
fi
COPY_EXIT=$?
ls -lh "$WEB_COPY"
sleep 10
echo "
TRIES=3
UPLOAD_EXIT=$?
echo "
echo "
break
else
seconden..."
sleep 45
fi
done
echo "
fi
echo ""
alexvanuxem
- Senior Boarder
hi just an update...
I am busy with weathercloud discussing the issue, they still claim taht it's not on their side, ....
tbc...
grtz
Alex
tbc...
grtz
Alex
