I’ ll also open a ticket on weathercloud about this.
Hopefully they will believe there is something wrong on their side ….
LD
meteocam to weathercloud
alexvanuxem
- Senior Boarder
Re: meteocam to weathercloud
hi,
it changed now i get 90% succes rate, I also changed the script,
could you check on your side, with the older scripts?
cheers
Alex
cheers
Alex
At the moment I have a success rate of 94% (40 % before), with an upload time of five minutes.
I haven't changed anything in my script! This makes the images of the timelapse much smoother.
In the meantime, no response from Weathercloud on my ticket (a week old)...
Greetings,
LD
Greetings,
LD
To be correct, I just received this mail:
Thank you very much for using Weathercloud and for upgrading to the Premium plan.
Following our investigation, we have confirmed that the issue originates on our side.
We have implemented corrective changes to resolve the problem.
If the issue persists after these updates, please let us know so we can continue the investigation.
LD
LD
