Aurora 2026 Rev-4.4Q Release
Re: Aurora 2026 Rev-4.1B Release
Update for forecast scripts and windchill/heatindex, use simple update method in setup screen only valid for rev 4.1B April 12th
Download wuforecast-update-April-13th
https://www.mediafire.com/file/mn2j9ytl ... h.zip/file
1.Fixed misalignment in forecast popup
2.Fixed overlap in small forecast module
3.Removed weather34-forecast-alt-2026.php option (please change to weather34-forecast-2026.php for future use)
4.Fixed alignment for windchill/heatindex phrase to close to icon
5.Fixed overlap when long airport name appears in Metar module
todo fix long place names overlap in earthquake module ..
..Brian..has always thanks for the feedback
lorenz1982
- Expert Boarder
Hi, I'm just reporting these alignment issues on Google Chrome.
- Immagine 2026-04-13 114127.jpg (158.55 KiB) Viewed 1143 times
hello you will have too put up with it for a while, im very busy with a new local project for a few weeks. that said charts are balanced across multiple screen sizes and devices so you may see some alignment differences but after cross checking across 18 variations of device resolutions i did not see any popping outside of the module widths, for example samsung devices renders css completely different from apple devices so there are variables to accommodate so this might render chrome slightly different to apple os and ios. have a good week.. brian
ios iphone 16 pro max
Re: Aurora 2026 Rev-4.3 Release
Simple-Update-Aurora-2026-April-27th
https://www.mediafire.com/file/kj3vzww2 ... 7.zip/file
Aurora-2026-Master-April-2026
https://www.mediafire.com/file/5mhp4o2i ... 6.zip/file
1.removed charts from small modules
2.reworked all small modules.
3.added color to sensor output values..(Ref Geoff)
4.minor change to Apple Watch and android watches view
5.earthquake pop up added chart and info
...Brian
...Brian
Re: Aurora 2026 Rev-4.3B Release
Sincere apologies forgot to include the wind module redesign
yesterday.
Simple-Update-Aurora-2026-4.3B-April 28th
https://www.mediafire.com/file/85e9jm7a ... h.zip/file
Aurora-2026-Master-April-2026-4.3B
https://www.mediafire.com/file/73kkxfzn ... B.zip/file
1.wind module redesign with ATC bearing
2.metar module alignment in phone view
3.apple watch fixed indoor module
4.apple watch fixed wind
..Brian
..Brian
lorenz1982
- Expert Boarder
Minor issue on iPhone 17 Pro Max.
- photo_2026-04-28_12-05-07.jpg (111.53 KiB) Viewed 894 times
Hi Brian, I wanted to ask if it would be possible to insert the forescast/alt module into one of the main modules, since I don't use the small modules. Thanks.weatherist34 wrote: Tue Apr 28, 2026 7:20 am Sincere apologies forgot to include the wind module redesignyesterday.
..Brian
- Screenshot_28-4-2026_19256_meteoroccamezzomonreale.altervista.org.jpeg (250.28 KiB) Viewed 1046 times
good morning
no problem added forecast large module option to position 8-12 in setup screen will push simple update later today ..hope this all sufficient.
@Lorenzo fixed metar alignment
..Brian
..Brian
Re: Aurora 2026 Rev-4.3D Release
Simple-Update-Aurora2026-4.3D-April 29th
https://www.mediafire.com/file/mfd24oaa ... h.zip/file
Aurora-2026-Master-4.3D April 29th
https://www.mediafire.com/file/x3zzlxgg ... D.zip/file
1.Added Large WU Forecast Module
2.Added position option to setup screen for WU Forecast Module Large
3.Adjusted Metar alignment
4.Fixed missing color range for large feels like module
5.Fixed Large clock module showing colors for time
..Brian
..Brian
lorenz1982
- Expert Boarder
With the latest update there is this problem:
- IMG_3643.jpeg (48.2 KiB) Viewed 834 times
I think the update file got messed up because I can reproduce it in any screen or resolution .. I will upload again shortly
Its mucked up for me too.
Re: Aurora 2026 Rev-4.3E Release
Simple-Update-Aurora-2026-4.3E
https://www.mediafire.com/file/tkni5rxa ... 9.zip/file
Aurora-2026-Master-4.3E
https://www.mediafire.com/file/zcb5g9ci ... 9.zip/file
hopefully fixes corrupt update ?? can't replicate any issue here with wind module (all browsers, device simulators checked)
Brian
Brian
Just upgraded to the latest simple update (version E) and the wind direction is still not working properly.
http://www.paulwilman.com/W34/
hi Paul can you go into setup and turn on ATC or set to yes ?pwilman wrote: Wed Apr 29, 2026 9:21 pm Brian,
