Aurora 2026 Rev-4.4X Release
Re: Aurora 2026 Rev-4.3F Release
Simple-Update-Aurora-2026-4.3F Apr 29
https://www.mediafire.com/file/o79bmn56 ... 9.zip/file
Aurora-2026-Master-4.3F Apr 29
https://www.mediafire.com/file/80f828ze ... 9.zip/file
fixes error with ATC bearing duplicate being displayed when set to NO in setup screen
..Brian
..Brian
With chrome the + sign of the large forecast cell is too high. Tiny detail, but just thought I would let you know. Other than that, I am finding it perfect!
Pauol
Pauol
Re: Aurora 2026 Rev-4.3G Release
Simple-Update-Aurora-2026-May-3.4G
https://www.mediafire.com/file/6vflc1ir ... G.zip/file
Aurora-2026-Master-3.4G-May-2026
https://www.mediafire.com/file/14o6cf2j ... 6.zip/file
thanks fixed (corrected)
1. forecast icon alignment fixed large module
2.new daylight/darkness small module option added
3.fixed forecast large module color script for current day temperature
4.increased input box size when adding path to MBrealtimeupload.txt in setup screen
*cautionary I'm aware a future PHP release will cause issues or generate errors in log files in this version 2026 .I will address these in the autumn mid October onwards as I don't foresee a imminent significant PHP release until later in the year. **Also note this will cause a significant headache on the older versions of template prior to 2026 it will require a lot of painstaking changes to many of the modules in the 10 themes !! , I will leave this to Boris to decide on but its not a 5 minute fix .thats just a part of software/web design you have to prepare for, it is no different in computing OS or mobile OS updates to operating systems or firmware which can render stuff broken if not updated to current releases .Think you will now understand why I focused on a (2026 version) straight forward single layout theme as opposed multiple layouts which was good but unsustainable for a single developer going forward.. worth noting web server providers often update PHP versions automatically but many have(the paid ones) the option to revert to older versions so not all is going to be lost .
.Brian
.Brian
Paul run this very simple small update file it polishes off the large forecast module appearance..
WU-Forecast-Simple-Update-2-May
https://www.mediafire.com/file/i2rmfkmu ... y.zip/file
hopefully thats it for now
..Brian
Just updated....huge thanks from me....I am loving this final version.
Noted about the PHP future warning. I still use the layout 1 of the older template for my main website. Would love to intergrate the latest version of this template into my main site, but I dont have the knowledge and have fallen out with neighbour who did the initial design!!!!
Paul
Paul
Ok Paul here is another small update to large forecast module basically uses short day names has I think the day Wednesday & Wednesday Night will push it out the module.pwilman wrote: Sat May 02, 2026 4:55 pm Brian,
Paul
Simple-update-WU-May3rd
https://www.mediafire.com/file/r0o2xbnd ... d.zip/file
your home page(index.php) is just using a iframe nothing complex . need help ? let me know but I don't have any of your web/ftp etc details anymore I stopped updating end users sites a year or so ago
<iframe src="https://content.meteobridge.com/dashboa ... /index.php" scrolling="no" marginwidth="0" align="middle" width="960.5" height="743"></iframe>
replace with below also you can adjust the height and width to suit if needed .
<iframe src="https://www.paulwilman.com/W34/index.php" scrolling="no" marginwidth="0" align="middle" width="960.5" height="743"></iframe>
Morning Brian,
Thanks so much for looking at this. I suspect it is more complicated than just changing the page width of the iframe. Just sent you an email to explain a bit more.
Paul
Paul
Re: Aurora 2026 Rev-4.3K Release
Simple-Update-Aurora-2026-4.3K May 6th
https://www.mediafire.com/file/wmcocj40 ... 6.zip/file
Master-Aurora-2026-4.3K May 6th
https://www.mediafire.com/file/ob844pd6 ... 6.zip/file
1.adds new wind compass design more flexible for devices and screen sizes and color implementation .easier to add extra info
2.adds day average and 5 minute wind direction indicators
3.adds forecast icon to large forecast WU module
4.fixed clock background in small module
..Brian
..Brian
lorenz1982
Tip: Perhaps a button to force a refresh would be helpful.
Sometimes I log into the web app and the data isn't updated immediately.
This was present in the old version.
- Immagine 2026-05-06 110145.jpg (76.2 KiB) Viewed 1154 times
Hello ,
no problem does this work for you bottom of sidemenu ??
or bottom right of template ??
lorenz1982
I am just testing out the new version and I have noticed the forecast alerts are not working for me, even though I have alerts on in my settings. The live updates appear to be working but not the forecast alerts. I am not sure if it’s something I have done or if it’s a bug.
Neil
Neil
Re: Aurora 2026 Rev-4.3M Release
Simple-Update-Aurora-2026-4.3M-May 9th
https://www.mediafire.com/file/978b1lka ... h.zip/file
Master-Aurora-2026-4.3M-May 9th
https://www.mediafire.com/file/7epib1j2 ... h.zip/file
1.Added force reload to sidemenu (Ref Lorenzo).
2.Added WU Forecast Notifications for rain, snow,thunderstorm..more forecast data can be added feel free to suggest. (Ref Neil)
3.Added new option in setup screen separate option to show WU forecast notification simple yes or no see below
..Brian
..Brian
Hi, I noticed this in the Bottom Small Modules in the 4.3M May 9th release:
"weather34-hardware-2026" and "weather34-daylight-2026" .. When you click the small graph icons (see pink arrows below), the Earthquake Detail window pops up instead of graphs for "hardware" and "daylight."
Thxs for all your work on this template
I just set up a new PHP 8.4.13 server for this and it's working well with my weather station and its historical data. The only problem I have is that the sun-moon, clock, and daylight modules are showing up as blank. I turned on error reporting in PHP, but not seeing anything obvious.
Is there an extension or other PHP config I am missing? I have the same problem when using the "Aurora 2026 Demo" data or my own weather station.
Thanks for all your hard work on this over the years, Brian. It is appreciated!
