MB Pro2: no data19num nor data20num available?
WS Heinenoord
- Senior Boarder
I'm looking at some MB Pro2 screens and note that Data sent & -received are not available in the database and not available for a graph. Is that a setting that needs to be changend, or have the two signals data19num or data20num been dropped from the database?
Re: MB Pro2: no data19num nor data20num available?
data19 and data20 measure tx and rx data volume sent since reboot. This data is not available on the PRO2 platform, therefore I stripped it there.
Background: Network adapters on PRO2 do not report the volume data via shell command "ifconfig" which I used for PRO. If someone has a hint where to read it from on the PRO2 I could try to get it implemented in future releases. On the other side, I didn't have the feeling that this data is much used anyway.
WS Heinenoord
- Senior Boarder
I used it with my MB Red to try spotting where the hourly CPU-% spiking came from. But even with network disabled the spiking continued.
