Aurora 2026 Rev-4.4X Release
Cavaliere
Re: Aurora 2026 Rev-4.3Q Release
Post by Cavaliere »
weatherist34 wrote: Sun May 17, 2026 1:21 pm Hello no problem but sure the old versions have no problems , only issue may be a future php update will break things .im aware of two issues on older versions that need some reworking in terms of php future releases . in short if aint broke don't fix it just carry on as you are ..Brian
Where can I find the latest version of the previous model?
I can download it and install it on my website.
Thank you very much in advance.
Re: Aurora 2026 Rev-4.3S Release
Simple-Update-Aurora-2026-4.3S 8TH June
https://www.mediafire.com/file/xtdgnpow ... e.zip/file
1.PHP 8.5.5 verified
2.minor earthquake change
Screenshot 2026-06-08 at 10.30.54.png (265.13 KiB) Viewed 1887 times
Screenshot 2026-06-08 at 10.35.18.png (28.1 KiB) Viewed 1887 times
alexeysailman
Post by alexeysailman »
Hi, Brian!
I'm having a display issue on my Iphone 15 PRO MAX. I've tried different browsers and haven't changed the scale on my phone. However, it works fine on my Ipad 13 M5 or PC.
Re: Aurora 2026 Rev-4.3T Release
Simple-Update-Aurora-2026-4.T 22ND June
Download https://www.mediafire.com/file/gjjbmy6x ... e.zip/file
1.Verified for PHP 8.5.7
2.Adds uptime to online module when in tablet or desktop view.
Master Aurora-2026 June 2026
https://www.mediafire.com/file/466bkm1z ... e.zip/file
*note as newer future Mac OS updates will no longer support Intel based apps I will only be able to develop with public PHP releases as my software does not support Beta versions of PHP only public releases unless I pay into another subscription (days are over where you could do one time purchases of software). So updates will be few and far between and very small mostly related to PHP as opposed to features.I purchased a new desktop Mac a couple months ago not thinking primarily about developing web stuff .Im not sure it would affect anything just lose the opportunity to be future proof confidently.
Alex im unable to reproduce this unless anyone else is experiencing the same I can't help. please provide a working url the browser source may help reveal the anomaly .see below using simulator I only have a 17 pro max to use locally or a simulator and can't replicate the appearance your seeing on either ...Brian
Screenshot 2026-06-22 at 07.32.23.png (32.43 KiB) Viewed 1702 times
Screenshot 2026-06-22 at 07.32.54.png (127.18 KiB) Viewed 1702 times
Screenshot 2026-06-22 at 07.39.00.png (1002.4 KiB) Viewed 1702 times
alexeysailman
Hi, Brian! I figured out what the problem was: I had the "large" scale selected in my phone's settings (screen and brightness). So it's okay, it was my issue)
Re: Aurora 2026 Rev-4.3X Release
Simple-Update-July-2026-4.3X
https://www.mediafire.com/file/bs51sqqj ... X.zip/file
Master-Aurora-2026-July-2026-4.3x
https://www.mediafire.com/file/shqgzng8 ... x.zip/file
1.Verified for PHP 8.5.8 RELEASE
2.Minor change to realtime data module
3.Minor change to davis console forecast module
4.Windchill module phrase only present when below 5c or 41f will show persistent feel when above these values
Screenshot 2026-07-07 at 15.55.19.png (78.12 KiB) Viewed 1516 times
Screenshot 2026-07-07 at 15.49.38.png (97.4 KiB) Viewed 1516 times
Screenshot 2026-07-07 at 16.06.23.png (625.54 KiB) Viewed 1512 times
Re: Aurora 2026 Rev-4.3Z Release
Simple-Update-July-2026-4.3Z
https://www.mediafire.com/file/7wzqikz3 ... Z.zip/file
Master-July-2026-4.3Z
https://www.mediafire.com/file/ygx57w5t ... Z.zip/file
1.Minor change to Heat Index module where if greater than 32C/90F the caption reflects Heat Index or if below these values the word persistent feel will be displayed particularly beneficial for those who don't change module layout according to season i.e windchill and heat index
Screenshot 2026-07-25 at 07.02.25.png (1.08 MiB) Viewed 1348 times
Re: Aurora 2026 Rev-4.4A Release
Simple-Update-August-2026-4.4A
https://www.mediafire.com/file/zjw3vqhe ... A.zip/file
Master-Aurora-2026-August-2026-4.4A
https://www.mediafire.com/file/2hxuy24n ... A.zip/file
1.cleans up heat index module code
2.cleans up windchill code
3.minor workaround change to end of day file based on users running 2 versions of template , using the original 2025 version and also 2026 version .the single path setup in meteobridge to drive both versions (ref Daniel)
Screenshot 2026-08-02 at 18.17.02.png (1.16 MiB) Viewed 1247 times
Re: Aurora 2026 Rev-4.4B Release
Sincere apologies messed up the windchill module color coding for values in yesterdays release.
Simple-Update-August-2026-4.4B
https://www.mediafire.com/file/xpbsltls ... B.zip/file
Master-Aurora-2026-August-2026-4.4B
https://www.mediafire.com/file/qtjkmoyb ... B.zip/file
2.cleans up windchill module code (mk2 :( ref Geoff)
Screenshot 2026-08-03 at 07.48.54.png (1.17 MiB) Viewed 1223 times
weatherist34 wrote: Mon Aug 03, 2026 6:49 am 3.minor workaround change to end of day file based on users running 2 versions of template , using the original 2025 version and also 2026 version .the single path setup in meteobridge to drive both versions (ref Daniel)
Where can I see this change in the setup or how do I use this change or improvement?
Torsten
ToTo wrote: Mon Aug 03, 2026 2:21 pm
Torsten
Hello
No changes to be seen or required, in setup simply the end of day file reads the path or url you set in the setup screen to your mbrealtimeupload.txt . So if you run multiple versions of aurora it can use the meteobridge aurora output . Its a minor change nothing significant. Daniel was using two versions old and newer version the end of day file was scripted to use a simple path ../mbridge/MBrealtimeupload.txt now its uses whatever you set the path in the setup screen. Hope it makes sense if not have a large beer 🍺 or two and just carry on using it 😁…brian
Oh, okay, I get it. :)
I'm already doing that thing with the same path and the two MB versions.
Re: Aurora 2026 Rev-4.4C Release
Simple-Update-August-2026-4.4C
https://www.mediafire.com/file/i4291f1c ... C.zip/file
Master-Aurora-2026-August-2026-4.4C
https://www.mediafire.com/file/bm8yj959 ... C.zip/file
1.Setup screen code clean up removes unused strings
2.Heat Index code fix for caution
Screenshot 2026-08-04 at 18.20.43.png (1.13 MiB) Viewed 1173 times
Re: Aurora 2026 Rev-4.4D Release
Simple-Update-August-2026-4.4D
https://www.mediafire.com/file/igaaagtf ... D.zip/file
Master-Aurora-2026-August-2026-4.4D
https://www.mediafire.com/file/5npof8er ... D.zip/file
1.Adds additional wind data and precipitation amount to forecast module
2.Fixes color coding in forecast module when temperatures forecasted above 35c/95F
Screenshot 2026-08-11 at 19.31.19.png (59.23 KiB) Viewed 1222 times
Screenshot 2026-08-11 at 19.34.30.png (1.13 MiB) Viewed 1222 times
alexvanuxem
Post by alexvanuxem »
hi question please, if let's say i have 4.4 A, can I just upgrade to 4.4 D, or do I need to go through B, en C, before D?
Grtz
Alex
