Aurora 2026 Rev-4.4X Release
Re: Aurora 2026 Rev-4.4E Release
Simple-Update-August-2026-4.4E
https://www.mediafire.com/file/61ni0jl1 ... E.zip/file
Master-Aurora-2026-August-2026-4.4E
https://www.mediafire.com/file/4qrfc2tz ... p.zip/file
1.Adds small Meteor Shower Module
2.Add meteor module to set up screen option
Screenshot 2026-08-12 at 06.54.39.png (59.08 KiB) Viewed 1881 times
Screenshot 2026-08-12 at 07.11.48.png (296.35 KiB) Viewed 1881 times
@Alex 4.4E contains all updates to code since March 2026
alexeysailman
Post by alexeysailman »
Hi, Brian! I installed your latest update here, and now there’s an empty block. I tried it in Edge and on the iPad Pro 13 — same thing. At this point, there was a “large forecast” module. I tried selecting this module for positions 7, 8, and 9 — same result. And I also wanted to ask: the previous update was 170 KB, and this one is 4 MB — is this the new Meteor Shower Module?
Снимок экрана 2026-08-12 102229.png (1.36 MiB) Viewed 1963 times
Hello alex
Please provide a url so i can try and diagnose the server output.
I’ve checked a few other sites where 4.4E is installed and no
errors seen or blanks check this one for a comparison
https://meteoborgo.altervista.org/Aurora/index.php
Brian
alexeysailman
Rolled back to Rev 4.4C and everything worked
alexeysailman wrote: Wed Aug 12, 2026 7:57 pm Rolled back to Rev 4.4C and everything worked
Hello
Unfortunately i can’t reproduce it locally so without a url with the issue I can’t offer a solution or provide a fix
pwilman
Post by pwilman »
I have just updated to the latest version and have the same issue with the large forecast module. The URL for my site is www.paulwilman.com/W34
Paul
lorenz1982
Post by lorenz1982 »
Hello.
I have this overlapping problem.
Immagine 2026-08-13 084635.jpg (19.24 KiB) Viewed 1662 times
MeteoBorgo: www.meteoborgo.it
Thanks ill take a look later i have your ftp details so ill fix it
Lorenzo i have a new moon phase script to release just waiting for the new moon to pass before releasing
pwilman wrote: Thu Aug 13, 2026 8:43 am Brian,
Paul
hi Paul try it now ? https://www.paulwilman.com/W34/
pwilman
Post by pwilman »
Thanks for fixing and updating my site. All back working properly. was it an easy fix?
Paul
Re: Aurora 2026 Rev-4.4F Release
**UPDATE 4.4F AND MASTER 4.4F REMOVED SEE 4.4G POST !
1.Fix blank forecast module (numerous reports of blank module, due to php conflict of duplicate string loaded)
2.New Moonphase script added to modules and pop ups
3.New Small Meteor Shower small module
4.New Modules option added to set up screen
.todo update lunar events for 2027-2030
Screenshot 2026-08-14 at 09.09.01.png (100.92 KiB) Viewed 1955 times
Screenshot 2026-08-14 at 09.09.25.png (204.2 KiB) Viewed 1955 times
Screenshot 2026-08-14 at 09.14.10.png (1.18 MiB) Viewed 1955 times
Re: Aurora 2026 Rev-4.4G Release
Simple-Update-Aurora-2026-August2026-4.4G
https://www.mediafire.com/file/3b92o0tk ... G.zip/file
Master-Aurora-2026-August2026-4.4G
https://www.mediafire.com/file/yn5lf54h ... 6.zip/file
1.fixes corrupt console setup file !
2.has all the new and fixes of 4.4F released earlier see previous post
Brian
lorenz1982
Hello, I have this issue with 4.4G release:
iPhone 17 Pro Max:
iPad Pro M4 11”:
Re: Aurora 2026 Rev-4.4H Release
lorenz1982 wrote: Sat Aug 15, 2026 7:39 pm Hello, I have this issue with 4.4G release:
Good morning thanks found it one line / piece of misplaced css :oops:
Simple-Update-Aurora-2026-August2026-4.4H
https://www.mediafire.com/file/zlwmk772 ... H.zip/file
Master-Aurora-2026-4.4H August2026
https://www.mediafire.com/file/v396llwv ... 6.zip/file
1.fix forecast large module showing oversized rain forecast (ref Lorenzo)
Screenshot 2026-08-16 at 06.34.11.png (78.12 KiB) Viewed 1856 times
Re: Aurora 2026 Rev-4.4K Release
Simple-Update-Aurora-2026-August2026-4.4K
https://www.mediafire.com/file/4m62j8qc ... K.zip/file
Master-Aurora-2026-4.4K-August2026
https://www.mediafire.com/file/ysdl3q6i ... 6.zip/file
1.Forecast changes summary to specific data points , summary often produced long descriptive summaries that broke out of the css area , its not possible to control what WU API forecast summary produces it is often much longer when producing US(F non metric) summaries.
2.Verified use with PHP 8.6 first beta release
Screenshot 2026-08-20 at 17.49.12.png (64.32 KiB) Viewed 1878 times
Screenshot 2026-08-20 at 17.49.53.png (95.81 KiB) Viewed 1878 times
