Meteobridge VM crashes
azchrisf
Post by azchrisf »
I am having an issue with my Meteobridge VM setup under Proxmox. There are two issues:
1. The Meteostick sometimes does not appear on initial boot in the sensors, you have to goto Stations and click Save and it starts working for some odd reason. Console logs for the VM show the Meteostick is seen, so this is perplexing. Log:
setup (21.10.2026 12:11:32): use UTC stamp 2026-10-21 19:11:32 (1 tries)
dbase (21.10.2026 12:11:36): process started.
dbase (21.10.2026 12:11:36): Content of RAM database restored.
dbase (21.10.2026 12:11:38): database sync done (178 tables, 346/10102 writes).
wnetd (21.10.2026 12:11:39): process started.
system (21.10.2026 12:11:39): start of logging process initiated.
logger (21.10.2026 12:11:39): databases connected. Update interval 3600 seconds.
logger (21.10.2026 12:11:39): data logger started.
logger (21.10.2026 12:11:39): station 0 (RF Vantage), can't open device /dev/ttyMH: Invalid argument
logger (21.10.2026 12:11:39): station 0 (RF Vantage), connect to station failed.
2. I am having an issue where it randomly stops responding or crashes - in the last part I removed the GW1000 as a test to see if it was causing the issues (nope) -
You can see a segfault:
logger (21.10.2026 08:32:47): child process received termination signal (11) in functions: termination_handler < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get...
logger (19.10.2026 04:26:08): connect station 9 (System Data via Plug-in).
logger (19.10.2026 04:26:08): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (19.10.2026 04:26:08): services paused.
logger (19.10.2026 04:26:08): station 1 (PurpleAir), PurpleAir-c2d HW:2.0 SW:7.02
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 1 registered as Wind
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 2 registered as ISS
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 3 registered as UV/Solar
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 4 registered as Leaf/Soil
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 5 registered as Leaf/Soil
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 6 registered as Soil
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 7 registered as Soil
logger (19.10.2026 04:26:08): station 0 (RF Vantage), transmitter 8 registered as Soil
logger (19.10.2026 04:26:08): station 0 (RF Vantage), initialization string sent to device /dev/ttyMH
logger (19.10.2026 04:26:08): station 0 (RF Vantage), Meteostick Version 3.4
logger (19.10.2026 04:26:08): station 0 (RF Vantage), debug off
logger (19.10.2026 04:26:08): station 0 (RF Vantage), verbose off
logger (19.10.2026 04:26:08): station 0 (RF Vantage), output raw
logger (19.10.2026 04:26:08): station 0 (RF Vantage), output raw (10 bytes)
logger (19.10.2026 04:26:08): station 0 (RF Vantage), filter on
logger (19.10.2026 04:26:08): station 0 (RF Vantage), rx threshold set to -90db
logger (19.10.2026 04:26:08): station 0 (RF Vantage), listening to tx 1 2 3 4 5 6 7 8
logger (19.10.2026 04:26:08): station 0 (RF Vantage), bandwidth narrow
logger (19.10.2026 04:26:09): station 0 (RF Vantage), chip auth ok: 14
logger (19.10.2026 04:26:09): station 0 (RF Vantage), frequency band 915MHz (US)
logger (19.10.2026 04:26:14): station 2 (GW1000), Radio Frequency: 915 MHz
logger (19.10.2026 04:26:20): station 2 (GW1000), FW version: GW1000B_V1.7.8
logger (19.10.2026 04:27:14): sensors are now providing data.
logger (19.10.2026 04:27:14): services started.
logger (19.10.2026 16:27:26): child process received termination signal (11) in functions: termination_handler < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get...
logger (19.10.2026 16:27:26): disconnect station 0 (RF Vantage): exit
logger (19.10.2026 16:27:26): disconnect station 1 (PurpleAir): exit
logger (19.10.2026 16:27:26): disconnect station 2 (GW1000): exit
logger (19.10.2026 16:27:26): disconnect station 3 (User-defined): exit
logger (19.10.2026 16:27:26): disconnect station 9 (System Data): exit
logger (19.10.2026 16:27:26): data logger stopped.
logger (19.10.2026 16:27:26): databases disconnected.
logger (19.10.2026 16:27:26): parent process to be terminated.
logger (19.10.2026 16:27:26): databases connected. Update interval 3600 seconds.
logger (19.10.2026 16:27:26): data logger started.
logger (19.10.2026 16:27:26): connect station 0 (RF Vantage via USB serial).
logger (19.10.2026 16:27:26): connect station 1 (PurpleAir via SW Driver).
logger (19.10.2026 16:27:26): connect station 2 (GW1000 via TCP/IP).
logger (19.10.2026 16:27:26): connect station 3 (User-defined via Plug-in).
logger (19.10.2026 16:27:26): connect station 9 (System Data via Plug-in).
logger (19.10.2026 16:27:26): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (19.10.2026 16:27:26): services paused.
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 1 registered as Wind
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 2 registered as ISS
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 3 registered as UV/Solar
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 4 registered as Leaf/Soil
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 5 registered as Leaf/Soil
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 6 registered as Soil
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 7 registered as Soil
logger (19.10.2026 16:27:26): station 0 (RF Vantage), transmitter 8 registered as Soil
logger (19.10.2026 16:27:26): station 0 (RF Vantage), initialization string sent to device /dev/ttyMH
logger (19.10.2026 16:27:26): station 0 (RF Vantage), Meteostick Version 3.4
logger (19.10.2026 16:27:26): station 0 (RF Vantage), debug off
logger (19.10.2026 16:27:26): station 0 (RF Vantage), verbose off
logger (19.10.2026 16:27:26): station 0 (RF Vantage), output raw
logger (19.10.2026 16:27:26): station 0 (RF Vantage), output raw (10 bytes)
logger (19.10.2026 16:27:26): station 0 (RF Vantage), filter on
logger (19.10.2026 16:27:26): station 0 (RF Vantage), rx threshold set to -90db
logger (19.10.2026 16:27:26): station 0 (RF Vantage), listening to tx 1 2 3 4 5 6 7 8
logger (19.10.2026 16:27:26): station 0 (RF Vantage), bandwidth narrow
logger (19.10.2026 16:27:27): station 0 (RF Vantage), chip auth ok: 14
logger (19.10.2026 16:27:27): station 0 (RF Vantage), frequency band 915MHz (US)
logger (19.10.2026 16:27:32): station 2 (GW1000), Radio Frequency: 915 MHz
logger (19.10.2026 16:27:38): station 2 (GW1000), FW version: GW1000B_V1.7.8
logger (19.10.2026 16:27:56): station 1 (PurpleAir), PurpleAir-c2d HW:2.0 SW:7.02
logger (19.10.2026 16:29:28): give up waiting for sensors after 120 secs.
logger (19.10.2026 16:29:28): services activated.
logger (19.10.2026 22:29:31): child process received termination signal (11) in functions: termination_handler < get_set < get_set_number < send_wnet_nosensor < test_inetupload < get_set < get_set_long < get_set < get_set_long < get_set < get_set_long < get_set < get_set_long < get_set < get_set_long < get_set < get_set_long < get_set < get_set_long < get_set < get_set_long < get_set < g...
logger (19.10.2026 22:29:31): disconnect station 0 (RF Vantage): exit
logger (19.10.2026 22:29:31): disconnect station 1 (PurpleAir): exit
logger (19.10.2026 22:29:31): disconnect station 2 (GW1000): exit
logger (19.10.2026 22:29:31): disconnect station 3 (User-defined): exit
logger (19.10.2026 22:29:31): disconnect station 9 (System Data): exit
logger (19.10.2026 22:29:31): data logger stopped.
logger (19.10.2026 22:29:31): databases disconnected.
logger (19.10.2026 22:29:31): parent process to be terminated.
logger (19.10.2026 22:29:31): databases connected. Update interval 3600 seconds.
logger (19.10.2026 22:29:31): data logger started.
logger (19.10.2026 22:29:32): connect station 0 (RF Vantage via USB serial).
logger (19.10.2026 22:29:32): connect station 1 (PurpleAir via SW Driver).
logger (19.10.2026 22:29:32): connect station 2 (GW1000 via TCP/IP).
logger (19.10.2026 22:29:32): connect station 3 (User-defined via Plug-in).
logger (19.10.2026 22:29:32): connect station 9 (System Data via Plug-in).
logger (19.10.2026 22:29:32): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (19.10.2026 22:29:32): services paused.
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 1 registered as Wind
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 2 registered as ISS
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 3 registered as UV/Solar
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 4 registered as Leaf/Soil
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 5 registered as Leaf/Soil
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 6 registered as Soil
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 7 registered as Soil
logger (19.10.2026 22:29:32): station 0 (RF Vantage), transmitter 8 registered as Soil
logger (19.10.2026 22:29:32): station 0 (RF Vantage), initialization string sent to device /dev/ttyMH
logger (19.10.2026 22:29:32): station 0 (RF Vantage), Meteostick Version 3.4
logger (19.10.2026 22:29:32): station 0 (RF Vantage), debug off
logger (19.10.2026 22:29:32): station 0 (RF Vantage), verbose off
logger (19.10.2026 22:29:32): station 0 (RF Vantage), output raw
logger (19.10.2026 22:29:32): station 0 (RF Vantage), output raw (10 bytes)
logger (19.10.2026 22:29:32): station 0 (RF Vantage), filter on
logger (19.10.2026 22:29:32): station 0 (RF Vantage), rx threshold set to -90db
logger (19.10.2026 22:29:32): station 0 (RF Vantage), listening to tx 1 2 3 4 5 6 7 8
logger (19.10.2026 22:29:32): station 0 (RF Vantage), bandwidth narrow
logger (19.10.2026 22:29:32): station 0 (RF Vantage), chip auth ok: 14
logger (19.10.2026 22:29:32): station 0 (RF Vantage), frequency band 915MHz (US)
logger (19.10.2026 22:29:37): station 2 (GW1000), Radio Frequency: 915 MHz
logger (19.10.2026 22:29:43): station 2 (GW1000), FW version: GW1000B_V1.7.8
logger (19.10.2026 22:30:02): station 1 (PurpleAir), PurpleAir-c2d HW:2.0 SW:7.02
logger (19.10.2026 22:31:32): give up waiting for sensors after 120 secs.
logger (19.10.2026 22:31:32): services activated.
dbase (20.10.2026 00:00:38): deletion of per minute data between 1969-12-31 and 2025-10-19 initiated (36 sensors).
dbase (20.10.2026 00:00:38): deletion of per minute data done for 36 sensors.
system (20.10.2026 02:30:24): stop of logging process initiated.
logger (20.10.2026 02:30:24): parent process received termination signal (15).
logger (20.10.2026 02:30:24): child process received termination signal (15).
logger (20.10.2026 02:30:24): disconnect station 0 (RF Vantage): exit
logger (20.10.2026 02:30:24): disconnect station 1 (PurpleAir): exit
logger (20.10.2026 02:30:24): disconnect station 2 (GW1000): exit
logger (20.10.2026 02:30:24): disconnect station 3 (User-defined): exit
logger (20.10.2026 02:30:24): disconnect station 9 (System Data): exit
logger (20.10.2026 02:30:24): data logger stopped.
logger (20.10.2026 02:30:24): databases disconnected.
logger (20.10.2026 02:30:24): parent process to be terminated.
system (20.10.2026 02:30:27): start of logging process initiated.
logger (20.10.2026 02:30:27): databases connected. Update interval 3600 seconds.
logger (20.10.2026 02:30:27): data logger started.
logger (20.10.2026 02:30:27): connect station 0 (RF Vantage via USB serial).
logger (20.10.2026 02:30:27): connect station 1 (PurpleAir via SW Driver).
logger (20.10.2026 02:30:27): connect station 3 (User-defined via Plug-in).
logger (20.10.2026 02:30:27): connect station 9 (System Data via Plug-in).
logger (20.10.2026 02:30:27): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (20.10.2026 02:30:27): services paused.
logger (20.10.2026 02:30:27): station 1 (PurpleAir), PurpleAir-c2d HW:2.0 SW:7.02
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 1 registered as Wind
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 2 registered as ISS
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 3 registered as UV/Solar
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 4 registered as Leaf/Soil
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 5 registered as Leaf/Soil
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 6 registered as Soil
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 7 registered as Soil
logger (20.10.2026 02:30:27): station 0 (RF Vantage), transmitter 8 registered as Soil
logger (20.10.2026 02:30:27): station 0 (RF Vantage), initialization string sent to device /dev/ttyMH
logger (20.10.2026 02:30:27): station 0 (RF Vantage), Meteostick Version 3.4
logger (20.10.2026 02:30:27): station 0 (RF Vantage), debug off
logger (20.10.2026 02:30:27): station 0 (RF Vantage), verbose off
logger (20.10.2026 02:30:27): station 0 (RF Vantage), output raw
logger (20.10.2026 02:30:27): station 0 (RF Vantage), output raw (10 bytes)
logger (20.10.2026 02:30:27): station 0 (RF Vantage), filter on
logger (20.10.2026 02:30:27): station 0 (RF Vantage), rx threshold set to -90db
logger (20.10.2026 02:30:27): station 0 (RF Vantage), listening to tx 1 2 3 4 5 6 7 8
logger (20.10.2026 02:30:27): station 0 (RF Vantage), bandwidth narrow
logger (20.10.2026 02:30:27): station 0 (RF Vantage), chip auth ok: 14
logger (20.10.2026 02:30:27): station 0 (RF Vantage), frequency band 915MHz (US)
logger (20.10.2026 02:32:28): give up waiting for sensors after 120 secs.
logger (20.10.2026 02:32:28): services activated.
dbase (21.10.2026 00:01:33): deletion of per minute data between 1969-12-31 and 2025-10-20 initiated (36 sensors).
dbase (21.10.2026 00:01:33): deletion of per minute data done for 36 sensors.
logger (21.10.2026 08:32:47): disconnect station 0 (RF Vantage): exit
logger (21.10.2026 08:32:47): disconnect station 1 (PurpleAir): exit
logger (21.10.2026 08:32:47): disconnect station 3 (User-defined): exit
logger (21.10.2026 08:32:47): disconnect station 9 (System Data): exit
logger (21.10.2026 08:32:48): data logger stopped.
logger (21.10.2026 08:32:48): databases disconnected.
logger (21.10.2026 08:32:48): parent process to be terminated.
logger (21.10.2026 08:32:48): databases connected. Update interval 3600 seconds.
logger (21.10.2026 08:32:48): data logger started.
logger (21.10.2026 08:32:48): connect station 0 (RF Vantage via USB serial).
logger (21.10.2026 08:32:48): connect station 1 (PurpleAir via SW Driver).
logger (21.10.2026 08:32:48): connect station 3 (User-defined via Plug-in).
logger (21.10.2026 08:32:48): connect station 9 (System Data via Plug-in).
logger (21.10.2026 08:32:48): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (21.10.2026 08:32:48): services paused.
logger (21.10.2026 08:32:48): station 1 (PurpleAir), PurpleAir-c2d HW:2.0 SW:7.02
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 1 registered as Wind
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 2 registered as ISS
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 3 registered as UV/Solar
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 4 registered as Leaf/Soil
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 5 registered as Leaf/Soil
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 6 registered as Soil
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 7 registered as Soil
logger (21.10.2026 08:32:48): station 0 (RF Vantage), transmitter 8 registered as Soil
logger (21.10.2026 08:32:48): station 0 (RF Vantage), initialization string sent to device /dev/ttyMH
logger (21.10.2026 08:32:48): station 0 (RF Vantage), Meteostick Version 3.4
logger (21.10.2026 08:32:48): station 0 (RF Vantage), debug off
logger (21.10.2026 08:32:48): station 0 (RF Vantage), verbose off
logger (21.10.2026 08:32:48): station 0 (RF Vantage), output raw
logger (21.10.2026 08:32:48): station 0 (RF Vantage), output raw (10 bytes)
logger (21.10.2026 08:32:48): station 0 (RF Vantage), filter on
logger (21.10.2026 08:32:48): station 0 (RF Vantage), rx threshold set to -90db
logger (21.10.2026 08:32:48): station 0 (RF Vantage), listening to tx 1 2 3 4 5 6 7 8
logger (21.10.2026 08:32:48): station 0 (RF Vantage), bandwidth narrow
logger (21.10.2026 08:32:48): station 0 (RF Vantage), chip auth ok: 14
logger (21.10.2026 08:32:48): station 0 (RF Vantage), frequency band 915MHz (US)
logger (21.10.2026 08:34:49): give up waiting for sensors after 120 secs.
logger (21.10.2026 08:34:49): services activated.
Any help is appreciated.
Re: Meteobridge VM crashes
Signal 11 ist ein Segmentation Fault, also ein Programmabsturz. Um das zu untersuchen, bräuchte ich remote-Zugriff. Die Suche kann etwas umfangreicher werden, ich muss also um etwas Geduld bitten.
Credentials bitte an "info(at)meteobridge.com" senden.
gwhit_s11
Post by gwhit_s11 »
admin wrote:Signal 11 ist ein Segmentation Fault, also ein Programmabsturz.
Fair enough on the remote access, admin, but I'm not sure it's a totally random crash. That backtrace is the same few functions (get_set, send_wnet_nosensor, test_inetupload) looping over and over, which looks more like runaway recursion to me than anything VM related. Might be worth azchrisf switching the internet upload services off for a day first, cos if it stops crashing you've narrowed it down alot before anyone hands over credentials.
