Wind Speed average/s
Thoughts/differences on the following between
wind0wind-avg (by definition average of the wind speed)
wind0avgwind-avg (by definition average of the average wind speed (time used for initial average wind speed depends on station)
- Is an average of an average meaningful?
- When might one be more applicable over the other?
- What might be the best application to use wind0avgwind-avg
Re: Wind Speed average/s
Most weather stations report just measured wind speed (stored in Meteobridge as "wind0wind") and some kind of averaged wind speed (stored as "wind0avgwind"). Having those two sensors, Meteobridge can report max/min/avg data for certain time periods for both sensors.
Obviously when looking for gusts the "wind0wind-max" schema is best suited. When looking for averages you can just take the current average as reported from the station "wind0avgwind-act" or you can take an average Meteobridge is building on the reported non-averaged wind speeds "wind0wind-avgXX" where "XX" is the number of minutes to do the average with.
"wind0avgwind-avgXX" will be an average over averaged wind data coming from the station. Not sure if that makes too much sense.
I hope this does provide a bit more clarity and does not add confusion :-)
gwhit_s11
Post by gwhit_s11 »
admin, what averaging window does my station use for wind0avgwind before Meteobridge touches it?
gwhit_s11 wrote: Mon Oct 26, 2026 6:34 pm admin, what averaging window does my station use for wind0avgwind before Meteobridge touches it?
That is a valid question to your station manufacturer. When you share your station details, maybe some users in the forum have the same station and have found details in their station documentation.
liamwilliams
Post by liamwilliams »
Averaging an average is mathematically fine only when each station average is based on the same sample count and interval; otherwise it weights periods unevenly and adds extra smoothing/lag. For a Meteobridge-defined window, wind0wind-avgXX is usually the cleaner choice. wind0avgwind-avgXX makes sense mainly when the station’s internal averaging period already matches the period you care about—for example, comparing with the station’s own displayed average—not as a general substitute.
