Look at tomorrow and upload a quick fixpwilman wrote: Wed Nov 11, 2026 4:23 pm Brian,
Thanks for the update, in particular I really like the 2 new rainfall modules.
Just updated to the latest one, but the little chart icon at the bottom right of the new rainfall modeuls has disappeared. It means you cant open up the rainfall graphs from the main page. You can see this from my main site (www.paulwilman.com). Hopefully an easy fix.
Paul
Aurora 2026 Rev-4.4T2Release
Re: Aurora 2026 Rev-4.4T Release
lorenz1982
Thank you. There are some alignment issues on the iPad Pro 11" M4.
- IMG_0843.png (1.99 MiB) Viewed 118 times
- IMG_0844.png (1.97 MiB) Viewed 118 times
Good morning should be fine now I had your FTP details so I updated the two files . I will push an update fix later this evening ..have a good day.pwilman wrote: Wed Nov 11, 2026 4:23 pm Brian,
Paul
@Lorenzo I will look at it this evening sorry for the inconvenience ..
Brian
Good morning , I have made a minor position adjustment for charts but before I made it I wasn't seeing the same through the simulator but I will push a possible fix later tonightlorenz1982 wrote: Wed Nov 11, 2026 11:15 pm Thank you. There are some alignment issues on the iPad Pro 11" M4.
here is what Im seeing through the simulator on your site unfortunately all I have to test with, I no longer own any iPads
Thank so much for making the changes to the rain modules and updating my site for me. It all works wonderfully on my standalone version of your template (https://www.paulwilman.com/W34).
However, as you may remember I use an iframe to bring your template into my main site (https://www.paulwilman.com/). Here there is an alignment issue with the new rain modules and the buckets are pushed over to the right. I am sure this is something to do with me using the iframe and so down to me and my setup, but it was all OK yesterday when you first released this update. The alignment issue only seems to have occured after you updated my site this morning with the small chart icon?
Paul
Paul
Just notices that my webcam image is now out of alignment again on my main website (but not the standalone version)
Re: Aurora 2026 Rev-4.4T2 Release
Simple-Update-Aurora-2026-Nov-4.4-T2
https://www.mediafire.com/file/rnz35koq ... -.zip/file
Master-Aurora-2026-4.4-T2
https://www.mediafire.com/file/7p15kuvo ... 2.zip/file
contains alignment fixes mentioned in above posts .
1.Adds iPhone Duo support folded or unfolded
2.Replacement Icon for FOG in WU Forecast
3.Verified for PHP 8.6RC5 Release
4.Adds iPad m5 screen size support
5.adds new rain bucket relative indicators to rainfall and rain rate
6.slight change Davis forecast module descriptions
7.improved CSS across the template
8.minor changes to notifications
thanks Paul & Lorenzo sorry for the inconvenience ..joys of supporting new and older devices..
Brian
Brian
lorenz1982
Re: Aurora 2026 Rev-4.4T2Release
Thanks for everything.
Unfortunately, the issue still persists on the 11" iPad Pro.
I can work around it, though, by keeping the window smaller.
- IMG_3711.png (1.75 MiB) Viewed 40 times
- IMG_3712.png (2.79 MiB) Viewed 40 times
Good evening I didn’t realise it was a pro i just adjusted for m4 11”
I’ll take a look later see if i have a simulator for pro
Thanks for making the alignments changes. Looks like it was CSS issue.
I am having a few issues as well with the WU forecast module. It is never empty, but recently it quite often doesn't return the detailed forecast. Screenshot attached.
Paul
Paul
- Screenshot 2026-11-12 at 21.02.08.png (64.69 KiB) Viewed 22 times
