Yes noticing that as well especially when things come down to individual whims that would tend to get complicated for very little constructive purpose across a platform that supports multiple tens of different systems. One has to consider the 99/1% rule.
A classic example would be wind speed resolution in tenths of a mph when the typical (Davis) specs are Resolution 1 mph, start threshold 3 mph and Accuracy of +/- 2mph or +/-4% or +/-5% depending on the model. Where does tenths of a mph fit? Relative to the specs not very well at all.
Sure some anemometers have the electronics and corresponding accuracy to actually provide high resolution meaningful output relative to the specs but these are few and far between.
admin wrote:Well, Meteobridge got more and more complex over the years, so there will never be a bug-free version. But I try hard to get close to it.
Fair enough admin, cant argue with that really. For what its worth 6.4 never caused me any RF dropouts, mine just kept chugging along fine the whole time on the same Vantage Pro2 setup, so maybe it was down to specific hardware combos or distance to teh console. I did have a right nightmare a few versions back with my anenometer freezing up in cold weather though, turned out to be a dry bearing rather than software at all. Replaced it, proper simple fix, felt a bit daft after spending ages blaming Meteobridge for that one
