Webcam credential error
captgadget
- Expert Boarder
In my Meteobridge under webcam it shows Error: Camera URL not providing data: https://xxx.xxx.x.xx/cgi-bin/api.cgi?cm ... &password=. However,
when I go to my Meteobridge Aurora the correct picture is showing in there so what in the world is happening to me?
captgadget
- Expert Boarder
Re: Webcam credential error
Whoa! I'm totally wrong here. I went to Aurora, clicked the red button in the lower left corner of the photo and that is the wrong photo. The right temperature is showing over an old photo so I still have a problem that I don't how to fix.
captgadget, I had something similar with mine ages ago... turned out Meteobridge was just caching the old frame and bolting the live temp overlay on top, exactly what you described. What fixed it for me was clearing the cache via the "Live Image" settings and forcing a manual snapshot refresh, rather than mucking about with the camera URL itself since that bit was fine all along. Also worth checking if your camera's own snapshot interval is longer than what Meteobridge expects, mine was set to update every 10 mins and Meteobridge kept grabbing the same stale jpeg. Bit of a faff to track down to be fair, but once i sorted the refresh interval it never happened again.captgadget wrote:The right temperature is showing over an old photo so I still have a problem that I don't how to fix.
captgadget
- Expert Boarder
Thanks for the information. I will try that see if that works for me. Thank you
