in my Meteohub log I frequently find entries like:
"wmr928eval (15.09.2009 03:28:41): illegal data record in line 233920 while reading from file /data/weather/200904/raw: 2009041415554q uv0 0
wmr928eval (15.09.2009 04:09:47): illegal data record in line 233920 while reading from file /data/weather/200904/raw: 2009041415554q uv0 0
wmr928eval (15.09.2009 04:41:55): illegal data record in line 233920 while reading from file /data/weather/200904/raw: 2009041415554q uv0 0"
Is this quite normal or do I have to manually delete this data?
Especially after a reboot Meteohub finds many of these illegal data records ...
Thank you for your advice :-)
< @ Mod: Could you please move this posting to the software forum? - Thanks! >
Illegal data record found in line ... :-(
Re:Illegal data record found in line ... :-(
The "Cleanup Data" button on the "Inspect Data" page can usually tidy up that sort of thing.Nimbus43 wrote:Is this quite normal or do I have to manually delete this data?
David
- Senior Boarder
David:
Thank you for your help. Will give it a try.
Mario
Mario
- Senior Boarder
Tried to cleanup data and/or delete incorrect data but am unable to stop data logging (in sub-menu Maintenance). Meteohub continues to log the data. Is this a bug?
Not one I recall hearing of.Nimbus43 wrote:Tried to cleanup data and/or delete incorrect data but am unable to stop data logging (in sub-menu Maintenance). Meteohub continues to log the data. Is this a bug?
Maybe re-boot, then try again?
David
