WAN IP says "no internet access"
mfarmwald
Post by mfarmwald »
WAN IP says "no internet access". I get this whether I run DHCP or not. Both IP and Gateway are valid and working. What's going on?
Hostname: meteohub
Workgroup: farmwald
MAC: 00:04:5A:0F:83:A5
IP: 192.168.1.186
Gateway: 192.168.1.2
DNS: 192.168.1.2
WAN IP: no internet access
markhiseman
Re:WAN IP says "no internet access"
Post by markhiseman »
I've had a similar problem in the past, and have to run my NSLU2 with a fixed IP address (turn off DHCP).
Try this (nb the 'ignore' tip):
http://www.meteohub.de/joomla/index.php ... 6&catid=23
Mark.
csoup
Post by csoup »
I two am having the same problem. However I attempted the solution and had the system lock me out of the internet. As of this date I am, unable to get the item to connect the the internet. I followed the instruction with no success. Below is the list of information:
System Info:
Hostname: meteohub
Workgroup: Home
MAC: 00:18:39:A6:24:BE
WLAN MAC:
IP: 192.168.1.110
WLAN IP: inactive
Gateway: 0.0.0.0
DNS: 192.168.2.1
WAN IP: NO Internet Access
Network:
IP: 192.168.1.110
WLAN:
Net Mask: 255.255.255.0
Gateway: 0.0.0.0
DSN: 192.168.2.1
Workgroup: Home
Host Name: Meteohub
Port: 80
I am running the system through a router with no luck in making change with the router system either. I am running the system through a Linksys Router [WRT54G].
Patrick L Campbell
no gateway IP = no internet access. ;)
Please switch DHCP off and give your router's lAN IP as gateway IP.
rune
Post by rune »
Just of of curiosity. Is it a problem with the DHCP implementation? In the case of "mfarmwald" the settings look OK.
yeticat
Post by yeticat »
1 month ago It's all Ok. But now NSLU2 can't acces to Internet
I can't change the Getway, when I modified it and saved, always appears 0.0.0.0.
Can you help me ?
Ignore what it returns. After a reboot settings are as you stored them.
Joe200
Re: WAN IP says
Post by Joe200 »
I have the same problem since yesterday. But with some differences: all fields have the respective informations, except DNS:
Hostname: meteohub
Workgroup: HOME
MAC: *MAC ADRESS*
IP: 192.168.1.77
Gateway: 192.168.x.x
DNS:
After viewing this topic, I followed all the instructions** that admin gave here. But, until now, nothing.
**I unmarked DHCP from the "Network" tab in meteohub and gave my router's LAN IP as the Gateway. Then, I saved settings and restarted NSLU2. It restarted normally and made the normal bips. I can access perfectly to meteohub by writing 192.168.1.77 in browser. However, the "no internet access" problem continues.
I have normal access to internet, generally speaking.
Must I specify by hand the DNS in "Network" tab in meteohub? And what value must I introduce in "DNS" field? The same that my router have?
Joe200
Re: WAN IP says
Post by Joe200 »
Please I need help with this... :(
wfpost
Re: WAN IP says
Post by wfpost »
enter as
DNS
8.8.8.8
and
as gateway the IP of your router.
then it´ll work
Joe200
Re: WAN IP says
Post by Joe200 »
Thanks wfpost! :D
I tried what you said and it worked perfectly.
Thanks once again.
