Hi, it's still me.
> I sent you this email for you to submit an idea for météohub.
> I think it'd be handy to export the data (wind, pressure, rainfall, wind
> direction, humidity, temperature, maximum gust, temperature min-max ...)
> by
> setting the user.
> Either in text or Excel or OpenOffice, so that archived data as Excel or
> OpenOffice it would be super convenient.
> With the possibility of archiving scheduled every 15 minutes, 30 minutes,
> 45
> minutes and every hour.
> This would even although this time is based on the hour, for example,
> archiving every 30 minutes or archiving to 12:30 and another at 13:00, if
> every 15 minutes, archiving 12:00 one at 12.15, a 12.30 and at 12.45 ...
> its
> not that make a statement at 12:14, 12:15 Better is more convenient, I
> hope
> to speak, for I am French and I do not write very good English.
> I hope you like my idea
> Good evening
> Best regards
Idea export data archived data as Exce
Re:Idea export data archived data as Exce
Or even better: integration with MySQL so we can do lookups, manipulation & other nice stuff
Yes, a database sql, good idea!
The data could be exported to the database, you may choose to export the data as the maximum gusts of the day, rain, wind speed, wind direction, dew point, humidity, pressure, temperature The minimum and maximum temperature, minimum pressure and maximum, minimum and maximum moisture, all listed by date, they could choose as I suggested above, the frequency of registration, as every 15 minutes, 30 minutes, all hours, and those with fixed hours, eg for archiving every 15 minutes should be given his record at 15h00, 15h15, 15h30, 15h45, 16h00 and not 15h02, 15h17, 15h32, 15h47 and 16h02.
