how can i export the data to an exel file ?
is this possible ? is it possible to export just the temp for example ? regards from greece
exel export
skyewright
Re:exel export
The "HTML Templates" mechanism described in secrion 2.11.4 of the manual can be used for other things besides html.kiofen wrote:how can i export the data to an exel file ?
If you use that mechanism to set up a csv file, excel would be happy to read that.
The topic in the following link contains an example of a csv file I used to produce:
http://www.meteohub.de/joomla/index.php ... mitstart=4
