Hi all,
I've burned the 2.3 firmware onto my slug, and installed the latest meteohub using the small usb/big usb technique.
When the slug starts, it gives:
one medium beep
two high then one medium beep
three very quick medium beeps
The slug does not give the beeps which indicate its IP address.
Subsequently, the ready and ethernet LEDs are green.
From this point, I can ping it on 192.168.1.77, but cannot access the web admin page.
Logging in via SSH and doing a 'top' shows:
Mem: 13304K used, 17072K free, 0K shrd, 1916K buff, 6244K cached
Load average: 0.00 0.02 0.07 (Status: S=sleeping R=running, W=waiting)
PID USER STATUS RSS PPID %CPU %MEM COMMAND
1761 root R 792 1482 1.9 2.6 top
1472 root S 1984 941 0.0 6.5 sshd
941 root S 912 1 0.0 2.9 sshd
1482 root S 860 1472 0.0 2.8 sh
917 root S 624 1 0.0 2.0 stickit
683 root S 608 1 0.0 1.9 syslogd
256 root S < 600 1 0.0 1.9 udevd
685 root S 600 1 0.0 1.9 klogd
1 root S 564 0 0.0 1.8 init
971 root S 544 1 0.0 1.7 getty
1760 root S 436 917 0.0 1.4 sleep
873 root S 260 1 0.0 0.8 udhcpc
81 root SW 0 1 0.0 0.0 mtdblockd
4 root SW< 0 1 0.0 0.0 khelper
172 root SW< 0 5 0.0 0.0 usb-storage
591 root SW< 0 5 0.0 0.0 kjournald
2 root SWN 0 1 0.0 0.0 ksoftirqd/0
41 root SW< 0 5 0.0 0.0 khubd
3 root SW< 0 1 0.0 0.0 events/0
5 root SW< 0 1 0.0 0.0 kthread
38 root SW< 0 5 0.0 0.0 kblockd/0
56 root SW 0 5 0.0 0.0 pdflush
57 root SW 0 5 0.0 0.0 pdflush
58 root SW< 0 5 0.0 0.0 kswapd0
59 root SW< 0 5 0.0 0.0 aio/0
82 root SW 0 1 0.0 0.0 nftld
171 root SW< 0 5 0.0 0.0 scsi_eh_0
671 root SWN 0 1 0.0 0.0 jffs2_gcd_mtd4
root@LKG288307:~$
doing a 'df' shows:
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/mtdblock4 6528 5596 932 86% /
/dev/mtdblock4 6528 5596 932 86% /dev/.static/dev
tmpfs 2048 32 2016 2% /dev
/dev/sda1 412524 217558 173668 56% /media/sda1
tmpfs 15188 28 15160 0% /var/volatile
tmpfs 15188 0 15188 0% /dev/shm
The unit has previously (before this reinstall) been working fine.
Any thoughts please, anyone?
James
No web access to Slug!
Re:No web access to Slug!
setup of USB stick has failed. What does logfile on USB stick tell us that holds the image to be transferred?
The logfile has the following contents:
stickit started.
Sun Nov 1 11:36:52 UTC 2009
accepted file:/media/sda1/meteohub-v4.5-4GB.rar
waiting for target stick ... found.
unrar and copy /media/sda1/meteohub-v4.5-4GB.rar to /dev/sdb/ ...
James
stickit started.
James
looks like operation has not finished.
Did you abort the progress?
No, I didn't explicitly abort it. It finished sooner than I expected (i.e. less than around 20 minutes mentioned in the manual). I'm currently retrying the copy operation, and I will let you know how I get on.
Thanks for the help!
James
James
Good news - it's up and running again after redoing the copy.
Now I need to re-apply my activation code, which I can't currently access because it's on my corrupted Google Docs account. But that's another story!
Thanks for your help.
James
James
