I just did a clean install of Windows 7. I installed the latest version of Weather Display and Now I'm having problems importing meteohub's data.
When I stat weather display it sometimes doesn't import any data and other time it may import a couple hours then stops. Has anyone installed Windows 7 and having problems?
Weather Display & Windows 7
skyewright
Re:Weather Display & Windows 7
For any problems in WD to Meteohub communication via the logging protocol, the first test to run is a simple manual test using a browser, e.g.evan.mac wrote:Now I'm having problems importing meteohub's data.
http://your-meteohub-ip/meteolog.cgi?mode=data
If you don't see data in the browser using that then WD won't be able to see it either.
If that proves to be okay try taking a look in
WeatherDisplay => View => WS2010-13/WS2500 data logger setup/info
to see if there are any clues there.
PS. What version of Meteohub are you running. There was an important WD related change in v4.5g.
