Webcam
HeinrichH
Webcam
Post by HeinrichH »
To use a webcam, do you have special things to configure??
I'm trying to get the images from a Microsoft VX-3000 in Meteohub, according the manual the camera is supported and I have the camera connected to the VMware player but I don't get a image in Meteohub
Checking the remote....
Re:Webcam
Do you have VMware configured to have this USB device visible to Meteohub?
HeinrichH
Re:Webcam
Post by HeinrichH »
Yes, the camera is connected to the VMware player and the player icon shows connected
P3R
Re:Webcam
Post by P3R »
Since we don't have the same hardware it may not be the same problem but after upgrading from version 4.4d the camera that have always worked before stopped working for me. My guess is that something in version 4.5 broke the webcam functionality but since nobody else have responded with reports on how their webcams work I don't know. Maybe I'm the only one using webcams?
Would it be possible for Boris to please check this?
HeinrichH
Re:Webcam
Post by HeinrichH »
Your previous post is very clear, I found this webcam very cheap in a shop (20 Riyal = 4 Euro) so my thoughts where "Give it a try"
I hope Boris will fix this.
Re:Webcam
Webcam feature is a bit flaky as it largely depends on timing which always is criitcal with low power systems we use. I tested a bit and it turns out that increasing priority of spcacat process (which does low level reading from the webcam) improves stability. Next update will have that. Hopefully, webcam function will then be as with previous versions, but I cannot promise...
I also made experience in the past that using webcam can freeze some systems. So use it at your own risk...
P3R
Re:Webcam
Post by P3R »
With version 4.5i the webcam is working again. :woohoo:
Thank you!
