I upgraded from 2.7 back in April 09 and I am currently running v4.5c, kernel2.6.21.7 with WMR928.
Transmission to Weatherunderground has been stopping at 17:00 the last day of the month every month since then. The console receives the information properly.
I purchased the unit from Ambient Weather in Aug 2008. Do I need a new activation code???
Getting very fustrated.
Transmission stops on last day of month
havasurose
- Fresh Boarder
Re:Transmission stops on last day of month
You don't need a new license coe. licenses are not time restricted.
Does recording of weather data at WU start again on next day of new month?
Does just WU have this problem? Do dashboard and WD-Live work on last day of month?
Do you have "use local time instead of UTC" switch selected on Meteohub's settings page? (Could be some kind of timezone problem, when UTC has already skipped to the next month, data might be lost at WU not being ready for taking data for next month).
havasurose
- Fresh Boarder
I have the same problem with CWOP. Does not start again on next day of new month. I will uncheck the "use local time instead of UTC" and see if this works.
The option should be checked. I would expect problem, when not being checked.
Could you please give me your WU ID? I would like to have a look at the graphs there.
Do the graphs at WU extend past 5:00 PM on the last day of the month and the data not or are both graphs and data not making it there past 5:00 PM?
The reason I ask is that I have something similar with my solar radiation reporting from a VP2 at WU. On the last day of the month, the solar data will stop at 5:00 PM on the last day of daylight time months and 4:00 PM of the last day of standard time months. I'm in the Pacific TZ. The solar graph always plots out for the full day though and so shows that all that data was reported to WU.
So I've concluded that this must be a WU problem and not something in the Meteohub.
havasurose
- Fresh Boarder
KAZLAKEH26, the CWOP DW1372
havasurose
- Fresh Boarder
Neither data not graphs are making it past 5:00 pm. I'm on AZ time (American/Phoenix) time.
